Statics-Two wires holding traffic light
  • Thread starter Thread starter lrp3395
    Light Wires
The discussion focuses on calculating the tension in two wires supporting a 33 kg traffic light, with angles of 53° and 37° for the respective wires. The correct weight of the light is established as 323 N, using the gravitational constant of 9.8 m/s². Through various equations, the tensions in the left and right wires are determined to be approximately 230 N and 180 N, respectively. A participant acknowledges an earlier miscalculation regarding the weight used in their equations. The final calculations confirm that the tensions are consistent with the forces acting on the system.
lrp3395
I don't know what i did wrong
Find the tension in the two wires supporting the traffic light
Mass of light= 33 kg
θ of FT1= 53°
θ of FT2=37°
Ʃfx=0
Ft1cos53-ft2cos37=0
ft1cos53=ft2cos37
Ʃfy=mg
ft1sin53-ft2sin37=mg
ft1sin53=mg+ft2sin37
ft1=(ft2sin37+mg)/sin53
ft1=1.33ft2
1.33ft2=(ft2sin37+mg)/sin53
1.33ft2=.72ft2+mg
.61ft2=323.73 N
Ft2=530.7n
ft1cos53=ft2cos37
ft1cos53=423.84n
ft1=704.26n
Tension forces always pull away from the objects on which they act. In the horizontal direction, your equation is correct. Not so in the vertical direction.
This is what I got:
TLsin(53o) + TRsin(37o) - 294 N= 0 TRcos(37o) - TLcos(53o) = 0
TR = TLcos(53o)/cos(37o)
TLsin(53o) + TRsin(37o) - 294N= 0
TLsin(53o) + {TLcos(53o)/cos(37o)}sin(37o) - 294 = 0
TLsin(53o) + TLcos(53o)tan(37o) = 294N
TL(sin(53o) + cos(53o)tan(37o)) = 294N
TL = (294 N)/(sin(53o) + cos(53o)tan(37o)) = 234.79884N = 230N
TR = (234.79884 N)cos(53o)/cos(37o) = 176.9336 N = 180N
Left wire has 230N of tension
Right wire has 180N of tension
I don't know where you got the 294N from? 33kg * 9.8 = 323N. g is 9.8, not 8.9!
Your maths seems right though.
You can check your answer easily also. 230sin(53) + 180sin(37) = 292N, which is close enough (since you rounded your answers) to 294.
Well dangit... I guess I got that one wrong then!
PhantomJay is correct
Hope this helps.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
