[Statistics] Calculate the percentage
  • Thread starter LokLe
  • Tags
    Statistics
In summary, the formula for calculating percentage is (part/whole) x 100 or (part ÷ whole) x 100. To convert a decimal to a percentage, multiply by 100. To convert a fraction to a percentage, divide numerator by denominator and multiply by 100. To calculate a percentage increase or decrease, use the formula ((new number - original number) ÷ original number) x 100. To calculate a percentage of a number, multiply the number by the percentage expressed as a decimal. Percentage points refer to the actual increase or decrease in a percentage, while percentage is a ratio or proportion of a number.
LokLe
37
Suppose the average mark of a class in a test is 85. At most what percentage of the
students have got marks not lower than 90?
Markov's Inequality: P(X >= a) = E(X)/a
My attempt:
P(x>=90) = 85/90 = 17/18
Is my understanding of the equation correct? Thanks
Looks right. Strange question!
Likes LokLe
How does it look right @PeroK?
Can you at least kindly substantiate...you're considering confidence level or what...
LokLe said:
Homework Statement: Suppose the average mark of a class in a test is 85. At most what percentage of the
Relevant Equations: Markov's Inequality: P(X >= a) = E(X)/a
My attempt:
If you are asked for a percentage, you should express your answer as a percentage, ie. as [itex]94.\bar{4}\,\%[/itex] rather than [itex]\frac{17}{18}[/itex].
Likes chwala and SammyS
FAQ: [Statistics] Calculate the percentage
How do you calculate the percentage of a number?
To calculate the percentage of a number, you divide the number by the total value and then multiply the result by 100. The formula is: (part/total) * 100.
What is the percentage formula?
The percentage formula is: (part/total) * 100. This formula converts a fraction or ratio into a percentage.
How do you find the percentage increase or decrease between two numbers?
To find the percentage increase or decrease, subtract the old number from the new number. Then, divide the difference by the old number and multiply the result by 100. The formula is: ((new number - old number) / old number) * 100.
How do you calculate the percentage of a total in a data set?
To calculate the percentage of a total in a data set, divide the specific value by the total sum of all values in the data set, and then multiply by 100. The formula is: (specific value / total sum of values) * 100.
How can I convert a percentage back to a number?
To convert a percentage back to a number, divide the percentage by 100 and then multiply by the total value. The formula is: (percentage / 100) * total value.
