Steam Point Temp. Interval - check answer
In summary, the steam point temperature on this scale is 671.12 and the temperature interval between the steam point and ice point is 180.12.
Quelsita
49
QUESTION:
Suppose the numerical value of 492 is assigned to the ice point temperature [tex]\theta[/tex]ice=492.
a) Find the steam point temperature on this scale.
b) Calculate the temperature interval between the steam point and the ice point on
this scale.
SOLUTION a :
We know that the ratio [tex]\theta[/tex]ice/[tex]\theta[/tex]steam = 1.3661
and that [tex]\theta[/tex]steam - [tex]\theta[/tex]ice = 100
thus,
[tex]\theta[/tex]steam = (1.3661)([tex]\theta[/tex]ice)
[tex]\theta[/tex]steam = (1.3661) (492)
[tex]\theta[/tex]steam = 671.12
SOLUTION b:
If [tex]\theta[/tex]ice=492 and
[tex]\theta[/tex]steam=672.12
then
[tex]\theta[/tex]steam -[tex]\theta[/tex]ice =180.12
Is this really correct?
Thanks!
Yes, this is correct. The temperature interval between the steam point and the ice point is 180.12 on this scale. This scale is known as the Rankine scale, where the ice point is assigned a value of 492 and the steam point is assigned a value of 671.12. This scale is commonly used in thermodynamics and is based on absolute zero being assigned a value of 0. Therefore, the temperature interval between the ice point and the steam point is 180.12 degrees on this scale.
Related to Steam Point Temp. Interval - check answer
1. What is the steam point temperature interval?
The steam point temperature interval is the range of temperatures between which water can transition from liquid to gas (vapor) state. This interval is typically between 100-374 degrees Celsius, depending on altitude and pressure.
2. Why is it important to check the steam point temperature interval?
Checking the steam point temperature interval is important because it ensures that the water is at the correct temperature for steam to form. This is essential for various scientific experiments and industrial processes that rely on the use of steam.
3. How is the steam point temperature interval determined?
The steam point temperature interval is determined through precise measurements of temperature and pressure using specialized equipment. The results are then compared to standardized tables or equations to calculate the steam point temperature interval.
4. What factors can affect the steam point temperature interval?
The steam point temperature interval can be affected by altitude, pressure, impurities in the water, and the presence of dissolved gases. These factors can alter the boiling point of water, which in turn affects the steam point temperature interval.
5. What happens if the steam point temperature interval is not within the correct range?
If the steam point temperature interval is not within the correct range, the water will not produce enough steam or may produce too much steam, which can affect the accuracy of experiments or cause problems in industrial processes. It is important to regularly check and maintain the steam point temperature interval for optimal results.
  • Thermodynamics
