Still not getting getting correct solution
  • Thread starter Thread starter gmuniz
The discussion revolves around calculating the maximum force between two protons accelerated towards each other at 1650 km/s. The user references the conservation of energy principle, stating that initial kinetic energy (KE_i) equals final potential energy (U_f) when initial potential energy (U_i) is zero. They express confusion over the equations used, particularly the force equation derived from Coulomb's law and its relation to kinetic energy. Key questions include the meaning of KE_i and the force (F) in this context. Clarification on the derivation and application of these equations is sought to resolve the discrepancies in the solution.
gmuniz
Two protons are aimed directly toward each other by a cyclotron accelerator with speeds of 1650 km/s,measured relative to the earth. find the maximum force that these protons will exert on each other.
KE_i + U_i = KE_f + U_f ;where U_i=0 and KE_f=0,so KE_i=U_f
if r= (q^2/(4*pi*epsilon_0))(1/KE_i) then F=(1/(4*pi*epsilon_0))(q^2/r^2) but the solution comes out as incorrect.
Can you explain what this eqn is about - where does it come from?
What is the question ?
What is KE_i ?
What is F ?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
