I Stimulated Emission & Emitted photon direction
Stimulated emission occurs when an electron in a higher energy state drops to a lower state, emitting a photon that matches the original in wavelength, phase, and direction. This process is fundamental to laser operation and is explained through the principles of quantum mechanics. The discussion raises questions about the preservation of these properties during stimulated emission and suggests a potential analogy between absorption and stimulated emission in terms of CPT symmetry. Additionally, the concept of negative radiation pressure is introduced, proposing a new perspective on how photons could be influenced in a given direction. Understanding these phenomena could enhance the comprehension of laser mechanics and photon behavior.
RobbyQ
TL;DR Summary
I always understood that a photon of correct wavelength would raise the energy level of an electron (which is the case)
But reading about lasers and stimulated emission I read the following where the electron drops a level upon absorption:-
"A photon with the correct wavelength to be absorbed by a transition can also cause an electron to drop from the higher to the lower level, emitting a new photon. The emitted photon exactly matches the original photon in wavelength, phase, and direction. This process is called stimulated emission."
How is this possible i.e dropping to a lower energy level and how/why is the photon wavelength, phase, and direction preserved?
Science news on Phys.org
Stimulated emission-absorption equations would be exchanged if performing CPT symmetry, suggesting they are CPT analogs - also through B_{12}=B_{21} symmetry for their Einstein's coefficients.
If so, and absorption is from positive radiation pressure, pushing photons into a target (from given direction) ... maybe we should think about stimulated emission through negative radiation pressure, pulling of photons (in given direction)?
https://scholar.google.pl/scholar?q=negative+radiation+pressure
https://www.physicsforums.com/threads/negative-radiation-pressure.1053657/
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
