Undergrad Stochastic calculus: Ito's lemma and differentials
  • Thread starter Thread starter cppIStough
Ito's lemma provides a framework for understanding the dynamics of stochastic processes, particularly in the context of financial modeling. The discussion highlights the importance of using the correct form of the stochastic differential equation (SDE) when simulating processes like Brownian motion. While the equation dS = r dt + σ dW is standard, it may not yield accurate results in Monte Carlo simulations without proper application of Ito's lemma. The participants clarify that using F = log(S) is necessary to correctly apply Ito's lemma for certain calculations, especially in the context of options pricing. Overall, the conversation emphasizes the need for precise formulation in stochastic calculus to avoid simulation issues.
cppIStough
TL;DR
Ito's lemma and differentials: what's the difference?
Ito's formula states for some stochastic function F(S,t) where S evolves as dS = f(W,t)dt + g(W,t)dW and W is brownian motion:
$$dF = \partial_t F dt + \partial_xF dx + 1/2 \partial_{xx}F dt$$
So why question is, what does dF really mean here? I see in brownian motion we take $$dS = r dt + \sigma dW$$, but simulating this directly via monte carlo gives problems. Evidently the correct approach is to let F = log(S) and apply Ito's lemma. But why can't we just use $$dS = r dt + \sigma dW$$? I mean, it's an equation given, so why doesn't this work with monte carlo?
Did i put this in the wrong section?
Ito's Lemma tells you that the Ito Differential of an Ito process is itself an Ito process and describes the form of the latter. The Differential describes an infinitesimal change in the Stochastic process in question.
I think some of your formulae are maybe not what you intended. You refer to log(S) as though you are doing some Black Scholes type calculation.
W is the Brownian motion in your examples. Based on what you posted, this
dS_t = \mu dt + \sigma dW_t
means
S_t - S_0 = \mu * ( t - 0 ) + \sigma * ( W_t - W_0)
I put in the 0 and the W_0 just for explanation, but of course both are zero and can disappear.
If you meant the Black-Scholes thing, you include S in both the drift and volatility terms, and of course Monte Carlo works, but I don't know which part you are not clear on
The standard _A " operator" maps a Null Hypothesis Ho into a decision set { Do not reject:=1 and reject :=0}. In this sense ( HA)_A , makes no sense. Since H0, HA aren't exhaustive, can we find an alternative operator, _A' , so that ( H_A)_A' makes sense? Isn't Pearson Neyman related to this? Hope I'm making sense. Edit: I was motivated by a superficial similarity of the idea with double transposition of matrices M, with ## (M^{T})^{T}=M##, and just wanted to see if it made sense to talk...
