Stone is thrown from the top of the building.
  • Thread starter Thread starter patelneel1994
    Building
A stone is thrown downward from a 60 m tall building with an initial velocity of 20 m/s. The motion is analyzed using the equation d = Vi.t + 1/2 a t², where d represents the distance fallen. The discussion highlights confusion about the sign convention for distance and velocity, emphasizing that the stone is moving downward. To find the time of impact, the equation must be rearranged and solved as a quadratic equation. Ultimately, the focus is on correctly applying the signs in the equation to determine the time until the stone hits the ground.
patelneel1994
A stone is thrown from the top of a building with an initial velocity of 20 m/s downward. The top of the building is 60 m above the ground. How much time elapses between the instant of release and the instant of impact with the ground?
Vi = -20 m/s height = 60 m
t = ?
d = Vi.t + 1/2 a t2
Couldn't figure out. How to use height as a distance?
It has the same dimension ! The equations are OK.
So 60 m = -20m/s . t + 1/2 a t2
60 m = -20m/s t - 4.9 m/s2 t2?
What should I do after this ...
You seem to be using the convention that up is positive, which is fine. But is the stone traveling 60 m downward or upward? What does that tell you about the sign of the 60 m in your equation?
Solve for t. (Hint: quadratic equation.)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
