STRACT: Understanding the Complex Conjugate of a Function
The discussion centers on finding the complex conjugate of the function w(z) = e^{sin(z)}. The initial solution presented was w(z*) = e^{sin(z*)} and w(x - iy) = e^{sin(x - iy)}, which was confirmed as correct. A request for proof of this definition was made, emphasizing that the conjugate of a complex function w(z) = w(x + iy) is w(z*) = w(x - iy). The explanation provided referenced the relationship between e^{iθ} and its conjugate, illustrating how the product of a function and its conjugate results in unity, thereby supporting the definition of complex conjugation. Understanding these relationships helps clarify the concept of complex conjugates in functions.
leoneri
I have a complex function
w\left(z\right)=e^{sin\left(z\right)}
What is the conjugate?
2. The attempt at a solution
The conjugate is
w\left(z^{*}\right)=e^{sin\left(z^{*}\right)}
w\left(x-iy\right)=e^{sin\left(x-iy\right)}
My question is, is my answer correct? If I wrong, could you tell me what is the right answer and how to reach this correct answer?
The conjugate is
Your answer is flawless!
AB
Thanks. I was sure about that, but one of my friend said I was wrong. So, is there a way to proof it? Because I see it as a definition that whenever there is a complex function w\left(z\right)=w\left(x+iy}\right), then the conjugate is always w\left(z^{*}\right)=w\left(x-iy\right). I would be more than happy if someone can show me or point me to a proof that the above definition is always true.
But I think you need
W*(z)
and not
W(z*)
Ask your advisor B. ...L.P. !
Since that is a definition, we can't do so much to give a real proof. But you can imagine the case involving e^{i\theta}. In this case, using the Euler relation one can see
e^{i\theta}=\cos(\theta)+i\sin(\theta),
e^{i(-\theta)}=\cos(\theta)-i\sin(\theta) (by the symmetry of cos and anti-symmetry of sin wrt the change of the sign of \theta),
so
e^{i\theta}e^{i(-\theta)}=[\cos(\theta)+i\sin(\theta)][\cos(\theta)-i\sin(\theta)] = 1..
Here you can understand that the result of the product of the function e^{i\theta} and its complex conjugate leads to the correct answer 1 just by looking at the first part of the equality. The second part confirms the complex conjugation of e^{i\theta} and e^{-i\theta}. Thus a change in the sign of i makes the function be transferred into its complex conjugate phase.
AB
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
