Stress on an Axially Loaded Beam
  • Thread starter Thread starter paxprobellum
    Beam Stress
In a cantilever beam subjected to an off-center axial compressive load, both compressive and bending stresses must be considered. The total stress at a point is calculated using the formula S = -F/A + My/I, where F is the applied force, A is the cross-sectional area, M is the bending moment, y is the distance to the neutral axis, and I is the second moment of area. The bending moment M is influenced by the lever arm created by the off-axis load, which is determined by the distance from the load to the beam's center. It is suggested that M may be constant across the beam, represented as F*d, where d is the thickness. Understanding the relationship between the load position and the resulting moments is crucial for accurate stress analysis.
paxprobellum
Consider a cantilever beam of length L where a force F is applied in compression at the bottom of the beam. (An off-center axial point load.) Determine the stress at the top and bottom of the beam at x=L/2.
There is both compressive and bending stress in the beam. The compressive stress is -F/A and the bending stress is My/I, where F is the force, A is the cross sectional area, M is the applied bending force, y is the distance to the neutral axis, and I is the second moment of area.
Applying this force is the same as a pure bending moment, except you gain additional compressive stress. Thus, at all points in the beam, the stress is:
S = -F/A + My/I
Most of the beam will be in compression, and a smaller part of the beam will be in tension.
My difficulty is determining what M is. In cantilever problems with transverse loads, M = M(x) = F*(L-x). I have a feeling M is not a function of x, but is constant over the whole beam. I think its F*d, where d is the thickness of the beam, but I'm not really sure why this is the case.
Agreed. Could the lever arm that produces M have something to do with the nature of the off-axis load...?
Yes. The moment is produced due to the lever arm. I suppose the lever arm appears as the force drifts from the center. So the lever arm must be the distance to the center of the beam, or half the thickness.
Good?
Sounds good.
Mapes said:
Sounds good.
Thanks ;)
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
