Stress profile of pressurized bent shell
In summary: It also brings up the concept of deviatoric stress and how it relates to the strain tensor in problems where the state of stress is not statically determinate. The conversation also mentions how the stress-strain response and Hooke's law play a role in determining the state of stress. Lastly, it touches on how the shape of the material, such as a bent torus, can affect the stress and strain components when pressurized.
ff12120
Consider a pressurized cylindrical shell of radius r and pressure p, which at equilibrium has a nonvanishing in-plane stress components pr/2 and pr. This result is generically found by force-balancing.
However, if I bent a pressurized torus into this cylinder, then the pressure will still give stresses pr/2 and pr, but there should be a stress due to bending. How does this stress enter into the force balancing at mechanical equilibrium?
In a general elasticity problem, if we applied pressure to a material without changing its shape, the stress cannot be uniquely determined from the strains. Consequently, the stress-strain law only specifies the "deviatoric stress." Is there a "deviatoric stress" for shells, whose in-plane stresses are not the same (and so unlike hydrostatic stress)? In other words, suppose I have both a strain tensor and a pressurized shell. The force balance involves just the geometry of the final deformed state and the pressure. How does the strain tensor (which involves the knowledge of the undeformed state) enter into the force balance, which should uniquely determine the stresses in the shell?
In some problems, such as your pressurized cylinder problem, the state of stress is statically determinate. So, once you determine the state of stress, you can then determine the strains.
In other problems, you can't determine the state of stress without taking into account the stress-strain response (Hooke's law).
In the case of your "straightened-out torus," the metal will have to yield to get it into its new configuration, and, when you let go, it will remain in its new stress-free state. If the released configuration happens to be a perfect cylinder and, if you attach end caps, when you pressurize it, the stresses will be pr/2 and pr.
Chet
Related to Stress profile of pressurized bent shell
1. What is a "stress profile" in relation to pressurized bent shells?
A stress profile refers to the distribution of stresses within a pressurized bent shell structure. It shows the magnitude and direction of stress at different points on the shell's surface, providing insight into how the structure responds to external forces.
2. How is the stress profile of a pressurized bent shell determined?
The stress profile of a pressurized bent shell is determined through various analytical and numerical methods, such as finite element analysis. These methods involve solving a series of equations that describe the behavior of the shell under pressure, taking into account factors such as material properties and geometric constraints.
3. What factors affect the stress profile of a pressurized bent shell?
The stress profile of a pressurized bent shell can be influenced by several factors, including the shape and size of the shell, the material properties of the shell, the magnitude and distribution of the applied pressure, and any surrounding structures or supports.
4. What are the implications of a high stress profile in a pressurized bent shell?
A high stress profile in a pressurized bent shell can indicate areas of the structure that are experiencing high levels of stress, which can lead to deformation or failure if not properly addressed. It is important to identify and reduce these areas of high stress to ensure the structural integrity of the shell.
5. How can the stress profile of a pressurized bent shell be optimized?
The stress profile of a pressurized bent shell can be optimized through various techniques, such as adjusting the geometry of the shell, using stronger materials, or altering the distribution of external forces. Computer simulations and real-world testing can also help identify areas of high stress and inform design improvements to optimize the stress profile.
  • Mechanical Engineering
  • Science and Math Textbooks
  • Other Physics Topics
  • Poll
