String of LEDs in parallel w/correct resistors and a TIP31 Transistor.
A string of LEDs connected in parallel with correct resistors is controlled by a TIP31 transistor linked to a computer's sound card. The setup works well with one computer but causes the LEDs to light up brightly without responding to music on another. Suggestions for debugging include measuring input impedance, considering DC offset issues, and using a series capacitor for safer connection to the sound card. Proper biasing of the transistor and calculating the base resistor value based on current requirements are also recommended. The user resolved the issue by switching to the onboard sound card, which restored functionality.
Defkon
I have a string of leds hooked up together with the correct resistors in parallel, going out to a TIP31 transistor which then goes to the power cord and to a 3mm jack. This 3mm jack goes into my computer and my leds "dance" to the music, I assume is the change in voltage. Anyways, I have hooked this up to one of my computers and it works flawlessley, but when hooked up to my other computer, the LEDs light up very bright and do nothing else. I am not sure how to begin debugging or how to fix it.
If it makes any difference, I am using a sound card in the second PC. Any nudges in the right direction or solutions are appreciated.
It sounds like you are using the transistor as a switch. Think about how much current it would need to "turn on", and what the current requirements likely are of the sound cards. They may be intended to drive different things.
What do you think the input impedance is of your LED circuit? Have you thought of measuring it across different frequencies?
Good job tinkering, this was one of my first projects!
Sounds like a problem of DC offset to me. Can you show us the schematic diagram?
If you are connecting the base of the transistor directly to the computer sound card speaker output, then this could be risky.
It would be better to bias the transistor properly and then connect to the computer via a series capacitor. Maybe 10 uF would be a good starting value.
Measure the current your LEDs use. Divide this by the current gain of the transistor to get the base current.
If you don't know either of these, assume 2 mA for the base current. These transistors have a gain of up to 50, so this would allow up to 100 mA for the LEDs.
Then calculate the size of the base bias resistor.
It will be (supply voltage minus 0.6 volts) divided by the base current (in Amps).
So, for example, if the supply voltage was 12 volts and the base current was 2 mA, the base resistor would be (12 - 0.6) / 0.002 or 5700 ohms, so you would use a 5.6 K resistor from the +ve supply to the base.
You may have to increase this resistor value until the LEDs just light up with no sound and then light up to full brightness with loud sound.
Thank you for the responses, I have to travel for work the rest of the week, but I will start testing next weekend. I believe I need different resistors b/c this is not an onboard sound card. By the way I'm using 100 ohm resistors. and a 5v psu with 700ma.
Got it working, I just pulled the other card out and used the onboard sound. Thanks for your help!
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
