I String theory in 4 dimensions?
TheHeraclitus
TL;DR Summary
Does Non-critical string theory really allow only 4 dimensions? Why it's not more popular?
Non-critical string theory, on Wikipedia it says:
Although this allows the construction of a string theory in 4 spacetime dimensions, such a theory usually does not describe a Lorentz invariant background.
Has it been experimentally disproven or are other reasons for its apparent obscurity?
Extra dimensions in string theory are a virtue rather than a nuisance. That's because theory in more dimensions is rich enough to accommodate a model as complex as 4-dimensional Standard Model, through various types of compactification or brane constructions. String theory in 4 dimensions, on the other hand, lacks such additional degrees of freedom so it lacks the needed richness. It could be a theory of something, but not a theory of everything.
Likes TheHeraclitus and PeroK
What are the strings in string theory made of? This question puts one back into square one. The reason Einstein's theory of relativity does not work in sub atomic level. Like many theories it involves Calculus. Calculus always assumes infinity as something real when it is not. That is the basis of these theories. We do not need strings to define matter. It could be simple presence vs non presence. Just like 1 and 0. When matter is compressed to the maximum (What thought to be infinity before but there is a limit to infinity which defines this maximum.) then you can achieve the zero. The same zero present in black holes and outside the universe or before big bang.
  • Skeptical
Likes Motore and weirdoguy
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
In LQG and LQC there are solutions called "black to white transition". I'll add some references: (Rovelli)https://arxiv.org/abs/1905.07251 (Rovelli)https://arxiv.org/abs/2302.03872 (Rovelli)https://arxiv.org/abs/1803.06330 (Rovelli)https://arxiv.org/pdf/1802.04264 (Rovelli)https://arxiv.org/abs/2108.12823 https://arxiv.org/abs/2304.02691 https://arxiv.org/abs/2110.07589 https://arxiv.org/abs/2009.01788 https://arxiv.org/abs/1911.12646 https://arxiv.org/abs/1801.03027...
Hello everyone, I am seeking to better understand the conceptual foundations and potential consequences of "Two-Time Physics" (2T-physics), as developed by Itzhak Bars and others. My interest was sparked by a recent paper that attempts to explain anomalous results in particle physics (apparent superluminal propagation of virtual photons) within the framework of 2T-physics: Paper: https://arxiv.org/abs/2408.02696 Key quote from the abstract: *"...the problem... can be solved naturally...
