String Theory Instantaneous Teleportation
In summary, the conversation discusses the concept of teleportation using quantum entanglement and string theory. It is explained that quantum teleportation is not the same as traditional teleportation and cannot violate the speed of light. However, the idea of changing particles instantly across any distance is discussed in relation to string theory, but it is noted that this would violate relativity. The book "The Elegant Universe" by Brian Greene is also mentioned as a source of information on this topic.
philipp2020
34
Hi
As far as I understand, that teleportation using quantum entanglement is only partially instantaneous, because a classical channel has to be used to send the two qbits from Point A to B. So the speed of light is the boundary as how fast teleportation can happen one day using
this technology.
Now how is it with string theory. I read the book from Michael Green "The Elegant Universe". There it says that Particles are connected trough EM Ropes which allow instantaneous change of particles across any distance. Would it be then possible to use this theory one day for "real" instantaneous teleportation?
Regards
Philipp
No, that would violate relativity, which string theory is meant to be an extension of. In addition, note that what we mean by quantum teleportation is not the Star Trek idea you're probably thinking of. It is about detaching a quantum state from a particular bit of matter, not transmitting a matter configuration from one place to another.
Also, "The Elegant Universe" is by Brian Greene.
Thanks for your answer.
Why again would this violate general relativity?
Because relativity (specifically, special relativity) doesn't allow information to be transmitted faster than light. Instantaneous is certainly faster than light.
But the idea of changing an electron, and the the electron neutrino changing instantly as a result, no matter the distance, isn't that change a transfer of information? The information being that the electron has changed, so the electron neutrino changes because it received the information. Or am I misunderstanding something?
Otherwise this is a very good book, but if it really says so, well, it's simply wrong.
It's been awhile since I read that (loved that book, I though B.G was a great teacher), but I have always remembered his description of QM non-locality being consistent with the hard to grasp way that GR is not violated.
That said it's only recently that I recently got to some welcome clarity around the way, that is done. What travels faster than light, if it can be said to be a thing, is randomness. The same random results appear instantaneously at arbitrary distance. Despite the fact that this is truly mind-boggling - no one has figured out a way to make randomness useful for transmitting things - only for hiding them. That's how GR is protected. No information can travel - through true randomness.
There is a good book by guy who is a true specialist in the field. I found it pretty helpful, and it's very concise, and written for the non-mathematically fluent. His term is "Non-local randomness".
https://www.amazon.com/dp/3319054724/?tag=pfamazon01-20
Related to String Theory Instantaneous Teleportation
1. What is String Theory Instantaneous Teleportation?
String Theory Instantaneous Teleportation is a hypothetical concept in physics that proposes the ability to transfer an object or person from one location to another instantaneously, without the use of conventional transportation methods.
2. How does String Theory Instantaneous Teleportation work?
According to String Theory, all matter is made up of tiny strings that vibrate at different frequencies. By manipulating these strings, it is theoretically possible to create a "wormhole" or shortcut through space and time, allowing for instantaneous teleportation.
3. Is String Theory Instantaneous Teleportation possible?
Currently, there is no experimental evidence to support the existence of String Theory Instantaneous Teleportation. While the concept is mathematically sound, it is purely theoretical and has not been proven to be possible in the real world.
4. What are the potential applications of String Theory Instantaneous Teleportation?
If String Theory Instantaneous Teleportation were to become a reality, it could revolutionize transportation and travel. It could also have implications for space exploration and the ability to colonize other planets.
5. What are the challenges facing String Theory Instantaneous Teleportation?
Aside from not having any experimental evidence, there are several technical and scientific challenges that would need to be overcome for String Theory Instantaneous Teleportation to become a reality. These include figuring out how to manipulate the strings, understanding the effects on the human body, and ensuring accuracy and safety during the teleportation process.
  • Beyond the Standard Models
124K
26K
