- 7,560
- 2,002
Made image adjustment and trying "Attach files" to put in here. Fence Lizard.
Thanks, I guess. Maybe I did not do enough magnification in using MS Paint? But those dimmed buttons while trying to put the image into the posts....berkeman said:I changed the attachments from thumbnails to full size. It looks like your pictures are only tiny parts of the images you uploaded?
The only thing I can think to do right now is, be sure to make a good original photograph, and then as appropriate, put into a PF post.gmax137 said:@symbolipoint I post images all the time with few issues. I have never had to magnify in MS Paint. I use the "Insert Image" button, and navigate to my saved image file. Once the image is in my draft post, I ignore the "thumbnail" buttons below the post.
symbolipoint said:Made image adjustment and trying "Attach files" to put in here.
If the issue is enlarging images that you attach or paste into your posts, you can do that in the window when you are creating your post. I usually use Copy/Paste to insert images into my posts, and after you insert the image you can click on it to highlight it (and see the 4 corner squares that define the size), and grab the lower right corner square to drag it down and right to enlarge the image.gmax137 said:I post images all the time with few issues. I have never had to magnify in MS Paint.
