MHB Stuck on this simultaneous equation
  • Thread starter Thread starter ai93
    Stuck
The discussion revolves around solving the simultaneous equations involving variables x and y. The initial attempt to solve the equations led to an incorrect conclusion, but through substitution and back-calculation, the correct values of x and y were found to be x = 1/2 and y = 1/4. Participants clarified the steps needed to arrive at the correct solution, emphasizing the importance of proper substitution. The final solution was confirmed, illustrating the effective use of algebraic manipulation. The conversation highlights the process of troubleshooting mathematical errors in solving equations.
ai93
A question I am working on
$$\frac{3}{x}+\frac{2}{y}=14$$ (1)
$$\frac{5}{x}-\frac{3}{y}=-2$$ (2)
let $$\frac{1}{x}=a$$ let $$\frac{1}{y}=b$$
$$\therefore3a+2b=14$$ (3) (x5)
$$5a-3b=-2$$ (4) (x3)
$$=15a+10b=70$$ (5)
$$15a-9b=-6$$ (6)
(5)-(6)
15a cancels out. Leaving 19b=76
$$b=\frac{76}{19}$$ $$x=4$$
But I have the answer wrong. I got this question from my textbook, there is no explantion the answer is $$x=\frac{1}{2} and y=\frac{1}{4}$$ But I can't seem to get there I don't know what I am doing wrong. Corrections please?
Mathematics news on Phys.org
Well, your solution is correct, substituting $b=4$ into one of the equations gives $a=2$. Hence back-substitution gives
$$a=2=\frac{1}{x} \Rightarrow x=\frac{1}{2}$$
$$b=4=\frac{1}{y} \Rightarrow y = \frac{1}{4}$$
which are the desired results.
Ohh yes. That explains it. Thank you!
Nice! You're welcome.
$$\frac{3}{x}+\frac{2}{y}=14\tag 1$$
$$\frac{5}{x}-\frac{3}{y}=-2\tag 2$$
You could multiply both equations by $xy$ to get:
$$3y+2x=14xy$$
$$5y-3x=-2xy\implies 14xy=-35y+21x$$
Thus, we have:
$$3y+2x=-35y+21x$$
$$38y=19x$$
$$x=2y$$
Go back to (1), and substitute for $x$:
$$\frac{3}{2y}+\frac{2}{y}\cdot\frac{2}{2}=14$$
$$\frac{7}{2y}=14$$
$$\frac{1}{2y}=2$$
$$4y=1$$
$$y=\frac{1}{4}\implies x=2\cdot\frac{1}{4}=\frac{1}{2}$$
Hence:
$$(x,y)=\left(\frac{1}{2},\frac{1}{4}\right)$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
