Sub woofers and tweeters wavelength
  • Thread starter Thread starter Istfan
    Wavelength
Subwoofers can be placed anywhere in a home cinema system due to their long wavelengths, which allow low-frequency sounds to diffract around obstacles, making them omnidirectional. In contrast, tweeters produce high-frequency sounds with shorter wavelengths that are more directional and require precise placement for optimal sound localization. The speed of sound is constant at approximately 340.29 m/s, and the wavelength decreases as frequency increases, leading to a significant difference in how sound waves propagate. High-frequency sounds cannot bend around corners effectively, necessitating accurate positioning of tweeters at ear level. Therefore, while subwoofers can be flexibly positioned, tweeters must be strategically placed to ensure sound quality.
Istfan
1. question
2.hello Dear ,
I have a question for you please ,
When you buy a home cinema system, you can place the subwoofer almost anywhere, even behind your couch.
But the tweeters (speaker for high frequencies) must be placed very accurately. Explain why!
Hint: use wavelengths for explanation (yes, with numbers). Give a strong argument.It is all about the size of wavelengthes. Think again back to the camera obscura.
my answer is :
speed of sound at sea level Cs = 340.29 m / s
is a constant
Cs = λ / T
Cs = λ (wavelength) . v (frequency)
With high frequencies like tweeters , we will get lower λ (wavelength)
For example of Frequency of 150 HZ sound wave (for sub woofers 20-200 Hz) .
The λ (wavelength) = 340.29 / 150= 2.2686 m
With 5000 Hz (tweeters have frequency between 2000-20000 Hz)
The λ (wavelength) = 340.29 / 10000 = 0.034029 m =3.4029 cm
The long wavelength sounds (lower frequencies) of the Subwoofer will diffract around the corners of the room more efficiently than the more directional, short wavelength sounds of the tweeters. So that we can put the subwoofer anywhere but the tweeters are directional . Since the bass frequencies have longer wavelengths, they will spread out more than the high frequencies. The high frequency sound spreads out less than the low frequency sound.
And for the Bass of Subwoofer it is called low-frequency, high-amplitude sound waves. So
lower-frequency = higher- λ (wavelength)
Higher λ (wavelength) = Higher T(Time duration needed)
Co (speed) = distance / Time
So ..
Higher T = higher distance
So , subwoofer can be put anywhere as its sound is omni-directional. The very long wavelength of the very low frequency bass sounds reproduced by the subwoofer usually makes it impossible for the listener to localize the source of these sounds . Because of long wavelength there is little difference between the information reaching a listener's left and right ears, and so they cannot be readily localized , so location does not matter .
But tweeters with high-frequencies have lower wavelength .
Lower-wavelength need lower time to move the distance
So lower time = lower distance
Than tweeters can be readly localized with short wavelengths and no difference between information reached to ears.
So we should put the tweeters accurately in place inline with ear level so all the room will be of wavelengths !
IS IT RIGHT ? :)
a correction .. or addition :
The long wavelength sounds (lower frequencies) of the Subwoofer will diffract around the corners of the room more efficiently than the more directional, short wavelength sounds of the tweeters. So that we can put the subwoofer anywhere but the tweeters are directional . Since the bass frequencies have longer wavelengths, they will spread out more than the high frequencies because wavelength are long enough to bend around posts and corners. The high frequency sound spreads out less than the low frequency sound because short wavelength are not able to bend around corners and posts so they are more directional.
Anybody is here ?>?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
