Submersible Bilge Pump for 1-2ms PPM Signal @ 50Hz
  • Thread starter Thread starter Martin2013
    Pump
A user is seeking a submersible bilge pump that can interpret a 1-2ms PWM signal at 50Hz for controlling a pump with a HobbyKing KK2.0 Flight control board. It is noted that most bilge pumps are designed to operate at full capacity and do not typically support variable speed control. The recommended solution involves using a motor controller to convert the RC signal to PWM, with caution advised regarding the power requirements of larger pumps. There is a discussion about the purpose of variable speed control, with the user clarifying their intent to build an underwater quadcopter. Suggestions include using cartridge-style bilge pumps and resources for further information on underwater vehicle design.
Martin2013
Hi,
Would anyone know where I can find a submersible bilge pump that understands a 1-2ms ppm signal at 50Hz?
I would like to control a bilge pump using the HobbyKing KK2.0 Flight control board ( http://www.hobbyking.com/hobbyking/store/__31656__Hobbyking_KK2_0_Multi_rotor_LCD_Flight_Control_Board_UK_Warehouse_.html ).
I have been desperately trying to find one!
Thank you!
Martin2013
Just so we are clear -I believe you mean a PWM signal.
I have wired a number of bilge pumps and am not aware of an RC control capable bilge pump or one that is meant to operate at anything less than 100% of capacity. They are merely intended to be made inexpensively and run reliably.
The only way that I am aware of to convert an RC signal to motor control PWM is to put a motor controller between your flight control board and the pump. Something like this:( http://www.pololu.com/product/1373 ) would work, I believe. The larger pumps can pull a considerable amount of power, so be sure to test the pump's power usage fully loaded before you size your motor control board. The 2100 GPH bilge pump in the stern of my boat will draw 10+ amps with a full head of water.
Hope that helps.
Hope that helps.
Thanks a lot for your reply.
So you suggest I link the KK2.0 board to the motor controller and link the motor controller to the speed controller? All of this for the 4 motors?
Which bilge pump do you suggest I use?
Thanks a lot for your help!
Why on Earth would you want a variable speed control on a bilge pump? Just wire it through a float valve switch - if there is water in the bilge it gets pumped out, if there isn't it doesn't.
That's because I'm building an underwater quadcopter.
I thought that might be your intent. An underwater ROV in quadcopter form...ought to be a masters thesis in hydrodynamics.
and yes, you will have to feed the motor controllers a signal they can understand, so be sure to get controllers that will take a PWM signal. In addition the controllers will have to support reversing the motor(s). Many do not.
Any of the cartridge style bilge pumps that you see available in stores have replacement motor cartridges. 360 gmh and 500 gph pumps are usually used, depending in the size of the vehicle. A model boat prop fits right on the output shaft. Google "DIY ROV" and you will find several descriptions of bilge pumps used as ROV thrusters.
The very best book on underwater vehicle design, construction and control is at the following link. It costs about $100 US and will be the cheapest thing you buy considering the time and money it will save you.
http://www.marinetech.org/underwater-robotics-textbook/
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
14K
