Sum of 4 Vectors: Magnitude & Angle
To find the sum of the four vectors A, B, C, and D, first convert vectors B and D from polar to rectangular coordinates using trigonometric functions. The components for B are calculated as 4cos(65)i + 4sin(65)j, and for D as 5cos(-235)i + 5sin(-235)j. Next, sum the x-components and y-components separately to obtain the resultant vector. The magnitude is determined using the Pythagorean theorem, while the angle can be found using the arctangent of the ratio of the y-component to the x-component. This method ensures clarity in handling two-dimensional vectors without introducing a third dimension.
Kp0684
What is the sum of the following four vectors in (a) unit- vector notation, and as (b) a magnitude and (c) an angle?... A=(2.00m)i + (3.00m)j...B: 4.00m, at +65.0 degrees...C= (-4.00m)i - (6.00m)j...D: 5.00m, at -235 degrees...i understand how to get the magnitude and the angle but how would i set this up... would i start with A and C and find their sum...i believe what's confusing me is B and D...otherwise i know how to set it up...need help...
HINT:Write all 4 vectors in component form.
Then simply add the 4 numbers for the "x" component and the 4 numbers for the "y" component.
Daniel.
Here are the formula's you will need to apply.
Given two vectors with components A = (i,j,k) and B = (a,b,c)
magnitude \sqrt{a^2 + b^2 + c^2}
scalar product: A.B = ia + b j + ck
scalar product: A.B = magnitude of A * magnitude of B * cos(t) where t is the angle between the two vectors A and B
sum A+B = (i+a,j+b,k+c) (this is a new vector, the scalar product yields a number)
marlon
okay, i get -2.00i - 3.00j - 1.17k when i sum it up...iam still lost on this one...need help again...
i, j and k represent the 3 directions of the space, for example high, wide and length. The object will be placed this 3 distances in the space from the point you consider as reference
I'm very confused! Where did "k" come from? You original post said
"... A=(2.00m)i + (3.00m)j...B: 4.00m, at +65.0 degrees...C= (-4.00m)i - (6.00m)j...D: 5.00m, at -235 degrees..." with only two dimensions.
I presume that the angles are measured relative to the positive x axis.
B would be 4cos(65)i+ 4sin(65)j and D would be 5cos(-235)i+ 5sin(-235)j
Adding those four vectors does not give you any "k" component.
Of course, once you have found the sum, you find the length by the Pythagorean theorem and the angle is arctan((j component)/(x component)).
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
