MHB Summing Formula Problem [Again]
  • Thread starter Thread starter susanto3311
    Formula
The discussion revolves around creating sum formulas for two arithmetic series: the first series is 1 + 3 + 5 + ... + 99, and the second is 2 + 6 + 10 + ... + 106. The formula for the sum of an arithmetic series is provided, which is S(n) = n/2 [2a + (n-1)d], where 'a' is the first term, 'd' is the common difference, and 'n' is the number of terms. For the second series, the values of a, d, and n are identified as a=2, d=4, and n=26, leading to a calculated sum of 1352. The discussion encourages users to show their progress to receive better assistance.
susanto3311
hello expert..
how do make sum formula for this below problem (2 question) :
please, see my attachment picture
thanks in advance..
susanto3311
Mathematics news on Phys.org
Hello, susanto3311![
How to make formulas for these sums?
$[1]\;1+3+5+7\cdots+99$
$[2]\;2+6+10+14+\cdots+106$
These two happen to be arithmetic series.
The sum of the first $n$ terms of an arithmetic series
$\quad$is given by: $\:S(n) \;=\;\frac{n}{2}\big[2a + (n-1)d\big]$
$\qquad\text{where: }\:\begin{Bmatrix} a &=& \text{first term} \\ d &=& \text{common difference} \\ n&=& \text{number of terms} \end{Bmatrix}$In [2], we have: $\:a=2,\;d=4,\;n=26$
Therefore: $\:S \:=\:\frac{26}{2}\big[2(2) + 25(4)\big]\:=\:1352$
We do ask that people posting questions show their progress so that our helpers know where you are stuck and can offer the best help possible. :D
The sum of the members of a finite arithmetic progression is called an arithmetic series, and is given by:
$$S_n=\frac{n}{2}\left(a_1+a_n\right)$$
To determine $n$, I would think of the terms of the first progression as $2n-1$ and for the second $2(2n-1)$ (and so how will the two sums be related?). Can you proceed?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
