MHB Sunshine's questions at Yahoo Answers regarding solids of revolution
  • Thread starter Thread starter MarkFL
    Revolution Solids
The discussion focuses on calculating the volumes of solids of revolution using the disk/washer method for two regions defined by specific curves. For part (a), the volume of the solid formed by revolving the region bounded by y=x^3 and y=2x around the x-axis is calculated to be 64√2π/21. In part (b), the volume for the region bounded by y=x^2+5, y=3, and x=-2 to x=2 when revolved around the y-axis is determined to be 16π. Both calculations are verified using the shell method, confirming the accuracy of the results. The discussion emphasizes the importance of visualizing the regions and applying integration techniques correctly.
MarkFL
MHB
Here are the questions:
Calculus Question-disk/washer method?
a)Let R be the region bounded by the given curves. Sketch R on a graph. If R is revolved around the x-axis, find the volume of the solid revolution by the disk/washer method.
y=x^3
y=2x
b)Let R be the region bounded by the given curves. Sketch R on a graph. IF R is revolved around the y-axis find the volume of the solid revolution by the disk/washer method.
y=x^2+5
y=3
x=-2
x=2
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Re: Subshine's questions at Yahoo! Answers regarding solids of revolution
Hello sunshine,
a) Here is a graph of the region $R$ to be revolved about the $x$-axis:
We may revolve the area shaded in red and then double the volume to find the requested volume.
The volume of an arbitrary washer is:
$$dV=\pi\left(R^2-r^2 \right)\,dx$$
where:
$$R=2x$$
$$r=x^3$$
and so we have:
$$dV=\pi\left((2x)^2-\left(x^3 \right)^2 \right)\,dx=\pi\left(4x^2-x^6 \right)\,dx$$
To determine the limits of integration, we may equate the two functions:
$$x^3=2x$$
$$x\left(x^2-2 \right)=0$$
$$x=0,\,\pm2$$
Hence, summing the disks by integrating, we find:
$$V=2\pi\int_0^{\sqrt{2}}4x^2-x^6\,dx=2\pi\left[\frac{4}{3}x^3-\frac{1}{7}x^7 \right]_0^{\sqrt{2}}=\frac{16\sqrt{2}\pi}{21}\left(7-3 \right)=\frac{64\sqrt{2}\pi}{21}$$
Now, whenever possible, I like to use the shell method to check my work.
The volume of an arbitrary shell is:
$$dV=2\pi rh\,dy$$
where:
$$r=y$$
$$h=y^{\frac{1}{3}}-\frac{y}{2}$$
and so we have:
$$dV=2\pi y\left(y^{\frac{1}{3}}-\frac{y}{2} \right)\,dy=2\pi\left(y^{\frac{4}{3}}-\frac{y^2}{2} \right)\,dy$$
To determine the limits of integration, we may equation the two functions:
$$y^{\frac{1}{3}}=\frac{y}{2}$$
$$y-2y^{\frac{1}{3}}=0$$
$$y^{\frac{1}{3}}\left(y^{\frac{2}{3}}-2 \right)$$
$$y=0,\,\pm2\sqrt{2}$$
Thus, summing the shells by integration we find:
$$V=4\pi\int_0^{2\sqrt{2}}y^{\frac{4}{3}}-\frac{y^2}{2}\,dy=4\pi\left[\frac{3}{7}y^{\frac{7}{3}}-\frac{1}{6}y^3 \right]_0^{2\sqrt{2}}=\frac{16\sqrt{2}\pi}{21}\left(18-14 \right)=\frac{64\sqrt{2}\pi}{21}$$
This checks with the result we obtained using the washer method.
b) Here is a graph of the region $R$ to be revolved about the $y$-axis:
We need only revolve the area shaded in red to find the requested volume.
Using the disk/washer method, we should observe that for $3\le y\le5$ we simply have a right circular cylinder of radius 2 and height 2, hence:
$$V_1=\pi(2)^22=8\pi$$
To find the remaining volume, we may use the washer method. The volume of an arbitrary washer is:
$$dV_2=\pi\left(R^2-r^2 \right)\,dy$$
where:
$$R=2$$
$$r=\sqrt{y-5}$$
and so we have:
$$dV_2=\pi\left((2)^2-\left(\sqrt{y-5} \right)^2 \right)\,dy=\pi\left(9-y \right)\,dy$$
Summing the washers by integration, we find:
$$V_2=\pi\int_5^9 9-y\,dy=\pi\left[9y-\frac{1}{2}y^2 \right]_5^9=\frac{\pi}{2}\left(\left(2\cdot9^2-9^2 \right)-(90-25) \right)=8\pi$$
Thus, the total volume is:
$$V=V_1+V_2=8\pi+8\pi=16\pi$$
Now, using the shell method to check our work, we find the volume of an arbitrary shell is:
$$dV=2\pi rh\,dx$$
where:
$$r=x$$
$$h=x^2+5-3=x^2+2$$
and so we have:
$$dV=2\pi x\left(x^2+2 \right)\,dx=2\pi\left(x^3+2x \right)\,dx$$
Summing the shells by integrating, we find:
$$V=2\pi\int_0^2 x^3+2x\,dx=2\pi\left[\frac{1}{4}x^4+x^2 \right]_0^2=2\frac{\pi}{2}\left(2^4+2^4 \right)=16\pi$$
This checks with our previous result.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
