Support reactions of a rigid, rectangular steel frame
The discussion focuses on solving for the support reactions of a rigid, rectangular steel frame resting on rubber pads, with shear force and moment applied. It identifies that there are eight unknown reaction forces and three equilibrium equations, indicating a statically indeterminate structure. Participants discuss the relationships between the deformations of the rubber pads, concluding that x-direction deformations of certain pads must be equal due to the frame's rigidity, while y-direction deformations must also match accordingly. The conversation highlights the importance of understanding degrees of freedom and the relationships between x and y deformations in the context of frame displacement. Overall, the thread emphasizes the need for compatibility equations to solve the problem effectively.
InYoung
Solve for support reactions of a rigid, rectangular steel frame sitting on rubber pads at the four corners (See attached), when a shear force and a moment is applied at some point on the frame. All the known variables are shown in black while the unknown are in red. It is a two-dimensional problem.
Force balances : Sum of X = T & Sum of Y = 0
Moment balance about point 1 (upper left hand corner) : (X3+X4)W + (Y2+Y3)L - M = 0
There are eight unknown reaction forces and three equilibrium equations. It seems like a statically indeterminate structure to the degree of 5 (8 unknowns - 3 equations). Could anyone offer help on how to find the appropriate compatibility equations? Thank you!
The four pads will deform, and they are identical.
Each extent of deformation relates to the shear force.
What can you say about the relationships between the different extents of deformation?
Umm, can I say that the x-direction deformation of pad #1 and that of pad #2 have to be the same given that the steel frame is rigid? Also for pads #3 and 4. As for the y-direction deformations would be equal for pads 1 and 4 (and for pads 2 and 3). Are these correct assumptions to make?
For small deformations, yes.
You can also get a relationship between the two different x deformations and the two different y deformations. Think about how the frame as a whole can move. How many degrees of freedom?
Three degrees of freedom: x and y translations and rotation about z-axis. In the case of translations, the two different x deformations must be identical and the two different y deformations also must be identical. In the case of rotation about z-axis, the two different x deformations must be equal and opposite (also true for the two different y deformations). Is this correct?
Thank you for the helpful pointers.
For a pure rotation, yes, but in general it will not be.
More interestingly, there is a relationship between the x deformations and the y deformations.
I'm afraid I can't see what that relationship is. Could you give me some pointers? Thank you!
Work in terms of the displacement of the frame. If its centre is displaced (Δx, Δy), and its orientation displaced Δθ, you can compute all the deformations from those.
So for a general frame displacement, if I look at the pure rotational deformations, these would be due to the differences in the shear forces (Y2 - Y1) and (X2 - X1). These deformations would be 'constrained' by the given geometry of the frame, as shown in the attached photo. (Again assuming small displacements). Is this correct?
Yes.
Relate tan theta to the given dimensions of the frame.
You can represent the whole movement of the frame as a rotational displacement, plus an x displacement, plus a y displacement.
haruspex said:
Yes.
Thank you very much for your help.
