Suppose the position of an object is given by a vector
The position of an object is defined by the vector r = (3.0t²i - 6.0t³j) m. To find r at t = 2.5 s, substituting the value gives r = 3(2.5)²i - 6(2.5)³j, resulting in r = 18.75i - 73.002j. The answer was initially reported as 19i - 73j, but the user faced issues with the homework system marking it incorrect. After some confusion, the user received clarification and resolved the problem. Accurate calculations are crucial for correct submissions in physics assignments.
sunnyday
Suppose the position of an object is given by r⃗ = (3.0t2i^ - 6.0t3j^)m. Where t in seconds.
Determine r⃗ at time t = 2.5 s. Express your answer using two significant figures. Express your answer in terms of the unit vectors i^ and j^.
plugging in 2.5 seconds to the r equation
r = 3(2.5)^2i-6(2.5)^3j -> 18.75i-73.002j -> 19i-73j
When I put this answer in my homework, it says it's wrong. I even tried (19i-73j) and it says it's wrong.
sunnyday said:
6(2.5)^3
Yes.
sunnyday said:
73.002
No.
Likes sunnyday
haruspex said:
Yes.
No.
oh what. nvm. that was so weird. thank u so much!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
