Supremum Proof Concerning Sqrt[2]
The proof provided in the book involves setting up a sequence of rational numbers that converges to $\sqrt2$ and then using the properties of limits to show that $\sqrt2$ is the supremum of the set in question.
MI6
The following is my book's proof that $\sup\left\{x\in\mathbb{Q}:x>0, ~ x^2<2\right\} = \sqrt{2}.$
http://www.mathhelpboards.com/attachment.php?attachmentid=527&d=1356865161
I don't follow the bit where it says "if [tex]s[/tex] were irrational, then [tex]w = \frac{\lfloor(n+1)s\rfloor}{n+1}+\frac{1}{n+1}.[/tex]"
Could someone please elaborate on that bit? How does s being irrational imply that?
all we are trying to do is find SOME rational number between s and s + 1/n.
the claim is that w is one such rational number.
note that since $\lfloor (n+1)s \rfloor < (n+1)s$ (s is NOT an integer, since s is irrational)
$\dfrac{\lfloor (n+1)s \rfloor}{n+1} < s$
so:
$w = \dfrac{\lfloor (n+1)s \rfloor}{n+1} + \dfrac{1}{n+1} < s + \dfrac{1}{n+1}$
on the other hand, we also have:
$(n+1)s - 1 < \lfloor (n+1)s \rfloor$
so:
$s = \dfrac{ns + s - 1}{n+1} + \dfrac{1}{n+1} < \dfrac{\lfloor (n+1)s \rfloor}{n+1} + \dfrac{1}{n+1} = w$
(all we are doing is explicitly finding a rational number between s and s + 1/(n+1)...we need a rational number to use because the set A only has rational members).
MI6 said:
The following is my book's proof that $\sup\left\{x\in\mathbb{Q}:x>0, ~ x<2\right\} = 2.$
It is true that $\sup\left\{x\in\mathbb{Q}:x>0, ~ x<2\right\} = 2$, but that is not what the book proves. The result is that if $s = \sup\left\{x\in\mathbb{Q}:x>0, ~ x^2<2\right\}$ then $s^2=2$. Or, to put it another way, $s=\sqrt2$.
FAQ: Supremum Proof Concerning Sqrt[2]
1. What is the definition of supremum in mathematics?
Supremum, also known as the least upper bound, is the smallest number that is greater than or equal to all the elements in a given set. It is a fundamental concept in mathematical analysis and is used to prove the existence of limits, continuity, and other important properties.
2. How is the supremum proof concerning sqrt[2] relevant in mathematics?
The supremum proof concerning sqrt[2] is relevant because it demonstrates the existence of a supremum in the set of positive real numbers. This proof is important in understanding the properties of real numbers and essential in many areas of mathematics, such as calculus and analysis.
3. Can you explain the process of proving the supremum of sqrt[2]?
To prove the supremum of sqrt[2], we start by assuming that there exists a limit that is less than the supremum. We then use the definition of supremum to show that this assumption leads to a contradiction. This contradiction proves that the limit must be equal to the supremum, and thus, the supremum exists.
4. How does the concept of supremum relate to other mathematical concepts?
The concept of supremum is closely related to other mathematical concepts, such as infimum, maximum, and minimum. The supremum is the smallest upper bound, while the infimum is the largest lower bound. The maximum and minimum are the largest and smallest elements in a given set, respectively.
5. Why is the supremum proof concerning sqrt[2] considered a fundamental proof in mathematics?
The supremum proof concerning sqrt[2] is considered fundamental because it demonstrates the existence of a supremum in a set of real numbers. This proof is essential in many areas of mathematics and serves as a building block for more complex proofs and concepts. It also helps to develop a deeper understanding of the properties of real numbers.
