Surface charge and volume charge density mathematical confusion
In summary, the total charge on a charged solid sphere with uniform volume charge density ρ is given by Q = ρ*4/3*∏*R^3, where R is the radius of the sphere. However, if any single spherical shell within the sphere has a uniform surface charge density σ, then the total charge on the sphere can also be written as ∫σ 4 ∏ r^2 dr with limits from 0 to R. This is because the charge within a spherical shell is equal to the surface area of the shell multiplied by the surface charge density. It is important to note that ρ and σ are not equal, but they are related by a single power of R. In order to find
user3
59
If you have a charged solid sphere with uniform volume charge density ρ, then the total charge on the sphere is
Q = ρ*4/3*∏*R^3 , where R is the radius of the sphere.
Now, if you also know that any single spherical shell from within the sphere has uniform surface charge density σ.
Then the total charge on the sphere could also be written as ∫σ 4 ∏ r^2 dr with the limits from 0 to R. That would give
Q = σ*4/3*∏*R^3
but how is σ = ρ ?
How can you write Q= ∫σ 4 ∏ r^2 dr?
It is Q= ∫σda
where da=rsinθdθdø
That will come out as σ.4πr^2.
Q= ∫σda is the charge on a spherical shell, a layer from the infinitely many that form the solid sphere. The total charge of the sphere is what I need.
user3 said:
but how is σ = ρ ?
Yes, you are right to question this. One is a volume charge density and the other is a surface charge density and so at the very least they should be related by a single power of R.
To obtain the area of a spherical shell of thickness dr, find the area of a sphere of radius r+dr and subtract this from the area of a sphere of radius r, supposing that dr is very small.
Alternatively, the integral ∫4πr2dr from 0 to R gives the volume enclosed by a sphere of radius R. Find this and multiply by ρ (since ρ is not a function of r) and you get the same answer.
Likes 1 person
It might help to consider a simpler analog. Suppose you have charge uniformly spread along the x-axis with a linear charge density λ. So, if you picked an infinitesimal interval dx, the charge in dx would be λdx. If you picked a mathematical point on the x-axis, how much charge would that point have?
You have a similar situation with the sphere. If you pick a mathematical surface in the sphere, how much charge would that surface have?
In order to capture some charge, you need to have a "surface" with some thickness, dr.
Likes 1 person
Q = σ*4/3*∏*R^3
but how is σ = ρ ?
This isn't correct .4πr2dr isn't the surface area of the spherical shell .Rather 4πr2dr is the volume of the spherical shell at a distance r from the center having thickness dr .This volume needs to be multiplied by the volume charge density in order to get the charge within the spherical shell . Further this charge needs to be summed up covering the entire volume of the sphere.
You are calculating charge within the sphere i.e charge within the volume of the sphere ,so volume charge density is required .
Moreover , Q = σ*4/3*∏*R^3 is dimensionally incorrect .
I get it. Thank you all.
Related to Surface charge and volume charge density mathematical confusion
1. What is surface charge and volume charge density?
Surface charge refers to the electric charge present on the surface of a material, while volume charge density is the amount of electric charge per unit volume of a material.
2. Why is there confusion in the mathematical equations for surface charge and volume charge density?
The confusion arises because both surface charge and volume charge density have different units of measurement and are represented by different mathematical equations. This can be confusing for those who are not familiar with the concepts.
3. How are surface charge and volume charge density related?
Surface charge and volume charge density are related through the electric flux, which is the amount of electric field passing through a given area. The electric flux is directly proportional to the surface charge and inversely proportional to the volume charge density.
4. Can surface charge and volume charge density be negative?
Yes, surface charge and volume charge density can be negative. This means that the material has an excess of negative charge, which can be caused by the loss of electrons or the gain of positive ions.
5. How are surface charge and volume charge density used in practical applications?
Surface charge and volume charge density are important concepts in understanding the behavior of electric fields and in designing electronic devices. They are used in various applications such as capacitance, electrostatics, and semiconductor physics.
