Surface Integral of a Cylinder
Syrena
Let S denote the closed cylinder with bottom given by z=0, top given by z=4, and lateral surface given by the equation x^2 + y^2 = 9. Orient S with outward normals. Determine the indicated scalar and vector surface integral to ∫∫ x^2 i dS (I have tried to solve this problem, but i don't think i have done it correct, since i get the answer 0. Please if anybody can help, this task is very importaint to get right)
\int\intx f dS=\int\int D f(X(s,t))||Ts\timesTt||
Since this is a cylinder, (i think) we can slice it into 3 parts,
S1 (lateral cylindrical surface), S2 (bottom disk) and S3 (top disk).
I parametrized the three smooth pieces as follows:
S1 (lateral cylindrical surface): x=3Cos(t), y=3Sin(t), z=t With bouderies 0\leqs\leq2π and 0\leqt\leq4
S2 (bottom disk): x=sCos(t), y=sSin(t), z=0. With bounderies 0\leqs\leq3 and 0\leqt\leq2π
S3 (top disk): x=sCos(t), y=sSin(t), z=4. With bounderies 0\leqs\leq3 and 0\leqt\leq2π
Then I found the ||Ts\timesTt|| for each S, that is
S1||Ts\timesTt|| =(3Cos(s), -3Sins,0)
S2||Ts\timesTt|| =(0,0,sCos^2 (t)+sSin^2 (t))
S3||Ts\timesTt|| =(0,0,sCos^2 (t)+sSin^2 (t))
Then I thought i could set in all that is in the parametrizised in the x^2 positision, dotted with the ||Ts\timesTt||.
S2 and S3 will then be 0 ( since ||Ts\timesTt|| have both 0 in the x position)
The last one S1
\int\int X^2 dS=\int\int (3^2 Cos^2 (s), 0, 0) ×(3Cos(s),3Sin(s),0) ds dt (boundaries 0 and 4(dt), 0 and 2π(ds))
=∫∫12 Cos^3 (s) dsdt (boundaries 0 and 4(dt), 0 and 2π(ds))
=12∫∫ Cos^3 (s) dsdt (boundaries 0 and 4(dt), 0 and 2π(ds))
=12∫ -3Sin(s)Cos^2 (s) dt (input 0 and 2π( for s)) (boundaries 0 and 4(dt)
This gives =12∫ dt which gives 0 <-- and i don't think this is the right answer. If anybody can help
Was this a typo? You should have x= 3Cos(s), y= 3sin(s), not "t".
It is a bit confusing to use the same letters as before for the parameters, but change their meaning.
Okay, so the "t" above was a typo. This is correct for the lateral surface.
S2||Ts\timesTt|| =(0,0,sCos^2 (t)+sSin^2 (t))[/quote]
You do know that s cos^2(t)+ s sin^2(t)= s, right? :-p
I'm not sure what you mean by the "x^2" position.
For the lateral sides, x^2= (3 cos(s))^2= 9cos^2(t) and idS itex is 3cos(s)ds dt so the integral is 27\int\int cos^3(s)dsdt
The last one S1
Actually, 0 is correct! This integral measures the flow of the vector quantity x^2i into the cyinder. Over the top and bottom, which are parallel to the xy-plane, there is no flow through the surface. For the lateral surrface, the flow into the cylinder on the x< 0 side is canceled by flow out of the cylinder on the x> 0 side.
I Thank Thee!
I did find though that I had some mistakes in my calculations:
is ∫12 (1/12(9sin(s)+sin(3s)) dt =∫(9sin(s)+sin(3s))dt instead of =12∫ -3Sin(s)Cos^2 (s) dt which I wrote at the beginning.
But =∫(9sin(s)+sin(3s))dt ( with boundaries 0 to 2π) also gives the answer 0.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
