Surface tension of water against a gas not being air
Surface tension is a property influenced by the interaction between two substances, such as water and gas. While data on water's surface tension against air is widely available, information on its surface tension with other gases like hydrogen is scarce due to complications like water's vapor pressure affecting measurements. The consensus is that replacing air with hydrogen may not significantly alter surface tension, but the solubility of hydrogen in water and contamination issues complicate precise assessments. Historical research by Girifalco and Good, along with resources like Adamson's "Physical Chemistry of Surfaces," may provide insights but can be challenging to interpret. Further literature search is encouraged for more detailed data on this topic.
anders_r_r
Surface tension is a property of two different substances. The surface tension of water against air under different conditions is given in many textbooks and data handbooks. However, if the air is replaced by, say, hydrogen, what will be the surface tension? Where will I have to look for the answer?
Thanks,
Anders
Interfacial energy measurements can be tough to find in the literature. To your specific question, one problem with performing measurements on water with various gases (or vacuum) is the vapor pressure of water- some will evaporate, contaminating the gas/vacuum. Consequently, there is a lot more data on mercury which has a much higher vapor pressure and does not evaporate.
http://www.springerlink.com/content/q435735865465450/
http://www.informaworld.com/smpp/content~db=all~content=a910127069
http://pubs.acs.org/doi/abs/10.1021/i360025a014
Sometimes, you will come across a paper with tables of this kind of data- I used to have one for various materials against dry air. If you do, please post it since I would like to have that data easily available as well!
Andy, thank you very much for your input. I will continue to search for some relevant litterature.
I have the feeling that replacing air with hydrogen does not make a big change to the surface tension. Can anyone tell whether this is correct. If it is correct, then why?
/Anders
Good question- I don't know. There's too many unknowns: the solubility of hydrogen in water, for example. I do know that the interfacial energy of water is pathologically sensitive to contamination, which makes precision measurements difficult.
Girifalco and Good have some papers where they attempt to calculate the interfacial energy from first principles; these came out in the 60's and 70's. I couldn't make heads or tails of it, tho.
Adamson's book "Physical Chemistry of Surfaces" is an excellent resource.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
