Swimming Speed Tracking with Sensors | Kent Zhou
  • Thread starter Thread starter kentigens
    Sensors
Kent Zhou is working on a final year engineering project focused on accurately tracking a swimmer's speed in a pool, facing challenges due to varying stroke patterns and body shapes. He is considering using infrared and ultrasonic sensors but seeks advice on effective sensor placement to monitor the swimmer's center of mass or midpoint. The project has budget constraints and requires a portable design, ruling out complex solutions like overhead cameras. Suggestions from the forum emphasize the difficulty of the project and the need for Kent to contribute significantly to the work. Kent is exploring the idea of using a horizontal array of sensors and algorithms to identify the swimmer's center during different strokes.
kentigens
Hi, I am a final year student whos doing engineering degree. My final year project involves tracking the speed of a swimmer inside a pool.
The current problem is that i don't have a good way of monitoring the swimmer's speed, which needs to be quite accurate(centimeters). Due to different stroke patterns and unregular shape of human body, it is very hard to find a way of getting the swimmer's speed during motion.
I've been thinking about infrared sensors, ultra sonic sensors and also other methods.
Is there any way of using sensors wisely and place them the right way so that i can accurately get the motion of the C.O.M. of the swimmer OR the mid-point of the body length?
Very appreciated for any suggestions or ideas.
Regards, Kent Zhou.
An overhead camera looking down on the swimmer measuring a target on the swimmer such as line or cross on the swimmer's back?
Regards, Kent Zhou.
Two comments.
First, since this is for a graded school project, you need to do the bulk of the work. Do not try to have the PF do your project for you. Even though this post probably qualifies under the "project" rule to be posted in the general technical forums like EE, you still need to show some effort on your part. We do not do your schoolwork for you.
Second, this is a VERY HARD project! Holy smokes. I'm a competitive swimmer, and I'm hard pressed to figure out a way to do it. Even with the video suggestion put forth so far, you are not going to see your sensor/reflector/marker much of the time from above. And most competitive pools are not deep enough for a single camera to sense the position of the swimmer with an under-Speedo-side marker.
What are YOUR thoughts so far? Are you a swimmer? Have you watched some competitivbe swimming videos on the Net? Let's hear your ideas please before this thread goes much farther.
Thank you for replying. What you have said above needs image processing and it is hard. what i have forgot to say is that the project is supposed to be "low cost" which limits how much resources we can have/spend on this project.
our design is actually on the side of the pool, plus the system needs to be portable. so...cant really bolt anything or suspend anything.
Thank you for your ideas anyway.
Two comments.
Thank you very much for your time. I do agree with you that I need to do most of the work which I am trying to get a solution right now. But sometimes, the views from experts could widen my ideas and for which i can get my work done in a relatively better quality, also saves time. XD.
Just some ideas needed or some devices that's available out there somewhere which I could not find with google.
Hmmm, I've had look at similar devices used in the olympics. They are really complicated and bulky and as I've replied to skeptic2 that this project has limited resources which can be spend on.
Theres a platform that runs along side of the pool which carries the cameras. The main ideas would be to have sensors placed on the platform and maybe some on the swimmer, possibly a band which can be picked up by the camera and then some image processing operating real time. TOO EXPENSIVE. What I have in mind is to have a own built PID controller or other types of controller (PCB) to control the speed of the platform.
Without too much expensive real time programming capability = can't use image processing, or anything like that.
Well, I am not a swimmer myself but i certainly can swim. I have talked to coaches about different strokes and how they will move, etc. Different strokes can have quite a different velocity pattern and the CoM moves up and down as well. Unlike a car or anything solid, there's an edge or fixed point which can be tracked... This is really bugging me...
My idea now is to have array of sensors lined up horizontally and have a little algorithm which determines wheres the center of the body for different strokes. and honstly, can't find any common patterns of arms/legs for different strokes...
Looking forward for your reply.
Thank you, Kent Zhou
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
