Switching/circuit breaker circuits
  • Thread starter Thread starter thavamaran
    Circuits
Thava is designing a circuit to control the power to a laser with a 5V supply and a bias current, requiring the ability to switch off inputs at a frequency of 100 kHz. Suggestions include using a single MOSFET for simple switching, which can achieve low on-resistance when activated. However, there are limitations on switching speed due to finite switching times and internal capacitance, which may affect performance at higher frequencies. Thava also inquires about current ratings, which range from 40 mA to 150 mA, and seeks reference circuits for guidance. The discussion emphasizes the need for a controllable switching mechanism that can adapt to varying switching times.
thavamaran
Hi guys, I am Thava. I am working in optical communication. Currently I want to design a circuit to turn of couple of inputs to my laser.
Say I have a supply of 5V to two pins of the laser, anode and cathode (pin 1 and pin 2). And then a bias current to another pin (pin 3).
At some interval of time, I want to switch off the 5 V input to cathode and of course anode is grounded; also switch off the input bias current.
The switching off time should be in about 100 kHz, and it should be controllable. It should be in a way that, if I supply a pulse with pulsewidth of 100 kHz, it should switch off exactly at the falling edge of the 100 kHz. Is it possible?
And the switching time should vary, like I can always change the switching time.
I just need some suggestions, ideas and discussion. I have so many ideas on doing it, but can't choose a proper way, so I just need some guidance. It will be much appreciated! Thank you.
Yes, 100 Khz should be very doable, but keep in mind there will be some finite switching time. Do you have any requirements regarding the "off" and "on" resistances of the switch? What about the amount of current going through?
The simplest type of switch just uses a single MOSFET - when you apply a gate voltage above the threshold, it has a very small resistance between source and drain. When you apply zero volts, it has a higher resistance.
One can then build more complex circuits uses multiple transistors to give a lower on-resistance and higher off-resistance, but at the cost of a slower response.
Sort of - there will be an upper limit on the frequency of the control signal. If you increase the frequency too high, a practical switch won't be able to keep up - it will always be somewhere between "fully on" and "fully off", because of the internal capacitance.
Thanks very much for your reply!
May I ask what you meant by finite switching time? At the moment, there is no requirements on on and off resistance, may I also ask why I need this?
Current rating would be from 40 mA to 150 mA.
Do you have any reference circuits or model that will feed into this applications? I need to a circuit to start with. Thank you.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
