B Symmetry regarding induced potentials?
The discussion centers on the relationship between induced potentials in electrostatics, specifically regarding a point charge and an uncharged conductor. The referenced paper suggests that the potentials due to these charges, denoted as ##\bar\phi_x(y)## and ##\bar\phi_y(x)##, are equal, prompting questions about the validity of this assertion. Participants clarify that this relationship can be derived from Green's Reciprocity Theorem, which applies under the assumption of vanishing charge densities at infinity. Additionally, it is noted that while the induced surface charge on the conductor must be considered, its contribution to the potential integration is zero due to the conductor being an equipotential surface.
haruspex
Insights Author
2024 Award
TL;DR Summary
Is it true that the potential arising at A from induced charges on conductor B from point charge q at C = that arising at C from induction on B from charge q at A?
A homework thread, https://www.physicsforums.com/threa...etal-sheet-along-a-spherical-surface.1057702/, references https://arxiv.org/pdf/1007.2175.pdf.
There is an uncharged conductor and a point charge. In the paper referenced, ##\bar\phi_y(x)## is defined as the potential at x due to the induced charges on the conductor when the point charge is at y.
As justification for eqn 10 it states that ##\bar\phi_x(y)=\bar\phi_y(x)##.
I cannot see why that should be true, but I cannot construct any counterexample.
Is it evident, or maybe some standard result?
Thank you for trying to clarify this point, I had already given up hope. But even if ##\bar\phi_x(y)=\bar\phi_y(x)## were true (assume this to be true for a moment, though it remains to be verified), what obvious relationship prompts the assertion that, since ##bar\phi_x(y)=\bar\phi_y(x)##, then ##\frac{q}{2} \nabla_x \phi_x(x) =- F(x)##?
This is an interesting result that can be deduced from Green's Reciprocity Theorem (see equation 5).
Likes PhDeezNutz, vanhees71 and haruspex
Darn, you just beat me to it! But I'll go ahead and post my response:
Start from two charge densities ##\rho_x,\rho_y## that give rise to two electrostatic potentials ##\phi_x,\phi_y## via Poisson's equation:$$\nabla^{2}\phi_{x}\left(z\right)=-\rho_{x}\left(z\right)/\varepsilon,\;\nabla^{2}\phi_{y}\left(z\right)=-\rho_{y}\left(z\right)/\varepsilon$$and suppose that the charge densities and fields vanish sufficiently fast at spatial infinity so that boundary terms are ignorable (in other words, the usual physicist's assumption!). Then Green's second identity (https://en.wikipedia.org/wiki/Green's_identities) can be written in terms of ##\phi_1,\phi_2## as:$$0=\int\left(\phi_{x}\left(z\right)\nabla^{2}\phi_{y}\left(z\right)-\phi_{y}\left(z\right)\nabla^{2}\phi_{x}\left(z\right)\right)d^{3}z=\varepsilon^{-1}\int\left(\phi_{y}\left(z\right)\rho_{x}\left(z\right)-\phi_{x}\left(z\right)\rho_{y}\left(z\right)\right)d^{3}z$$where the integration extends over all space. This result is known in electrostatics as Green's Reciprocity (https://en.wikipedia.org/wiki/Reciprocity_(electromagnetism)). Now specialize to point charges ##\rho_{x}\left(z\right)=q_{x}\delta^{3}\left(z-x\right),\;\rho_{y}\left(z\right)=q_{y}\delta^{3}\left(z-y\right)## located at positions ##x,y##:$$0=\varepsilon^{-1}\int\left(\phi_{y}\left(z\right)q_{x}\delta^{3}\left(z-x\right)-\phi_{x}\left(z\right)q_{y}\delta^{3}\left(z-y\right)\right)d^{3}z=\varepsilon^{-1}\left(q_{x}\phi_{y}\left(x\right)-q_{y}\phi_{x}\left(y\right)\right)$$In particular, if ##q_x=q_y## (as is apparently the case in the cited external reference), then the simple reciprocal relation ##\phi_{y}\left(x\right)=\phi_{x}\left(y\right)## indeed holds.
Likes vanhees71 and TSny
OK. But, besides the point charge, there will also be induced surface charge density on the conductor. So, the integration over ##\rho## should include integration over the surface of the conductor. However, you can show this integration equals zero using the fact that the conductor's surface is an equipotential surface and the net charge on the surface is zero.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
