fog37
- 1,568
- 108
- TL;DR Summary
- Systems, potential energy, and nonconservative forces
Hello,
I am trying to get my head around the idea of nonconservative forces doing work and changing the potential energy of a system.
First of all, forces acting on a system can be:
a) internal and conservative
b) internal and nonconservative (friction, pushes, pulls, thrust, etc.)
c) external and conservative
d) external and nonconservative
Potential energy is energy due to the spatial configuration assumed by two or more internal components of the system interacting via a conservative force. An external and conservative force would imply that the system and something outside of the system, in the environment, share potential energy... However, I think that potential energy can only be the energy of the SYSTEM and not between the system and something else. The correct explanation may be that external forces can be nonconservative but we cannot define potential energy in that case.
Example: a system solely composed of a rock. Planet Earth is not included on the system. The rock and Earth exert mutual gravitational and conservative forces on each other. But we cannot talk about the gravitational potential energy of the rock and Earth since Earth is outside of the system. What do you think?
In regards to the general statement ## W_{nc} = \Delta KE +\Delta U##, a nonconservative force (either external or internal) can do work that changes the potential energy and the kinetic energy of a system. Assuming ##\Delta KE=0## for an object moving at constant speed, we get ## W_{nc} = \Delta U##. We also know that the net work done by conservative forces ## W_{c} = - \Delta U##.
How do we reconcile the fact that potential energy ##U## cannot be defined for a nonconservative force? I know that ##F_c = \frac {dU} {dx}## and this cannot be done for a nonconservative force. However, it seems that both conservative and nonconserative forces can do work that changes the potential energy ##W_{nc} = \Delta U## and ##W_{c} = - \Delta U##. even if we cannot define a potential energy for a nonconservative force. Conservative forces do work that does not depend on path. However, the equation ##W_{nc} = \Delta U## seems to imply that a nonconservative force doing work ##W_{nc}## would also equal the change in ##U## regardless of the displacement over which the force acts...
I am clearly confused. I tried to re-read old threads but I am still unsure...
Thank you!
Thank you!
