Taylor Series - Range of values
wombat4000
im being asked for the first 4 non zero values for the taylor expansion of exp(x) which is simple, but then it asks for the range of x values that are valid for the expansion.
i have never come across ths before - any idea?
From the first four coefficients of the taylor expansion you can guess what the nth coefficient is going to be. Is there then some test you can use to find out when a sum (don't worry about it being a taylor series!) converges?
ratio test? integral test?
but how will working out if the sum convereges help with obtaining the valid x values?
The ratio test is useful for calculating when taylor series converge. Each of the terms of your sum is in terms of 'x' so the ratio test tells you when the sum converges in terms of x.
the question doesn't mention sum or convergence?
The taylor series expansion is going to be valid where the sum converges, or alternatively you can just write that the taylor series expansion for exp is valid everywhere if you've been told this fact.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
