Telescoping antenna -- why is there a knob on top?
In summary: Corona discharge noise is reduced by using a ball or capacity hat on the antenna, and a shorter whip is needed for resonance.
hacivat
28
TL;DR Summary
Does the knob at the end of a telescopic antenna have a significance?
This is probably a trivial or even a stupid question, the reason I am writing here is I couldn't find something satisfactory online. I am a new amateur radio operator. Currently enjoying listening to SW and MW bands. I have a nice radio receiver with a long telescopic antenna. I have noticed that the knobs at the end of telescopic antennas sometimes come in different sizes. Are they there only for ease of handling when increasing the length of antenna or preventing the end from slipping inside? Or do they have a significance in terms of some technical detail like introducing a capacitive load or so?
They are there to protect your eyes.
Likes rude man, Spinnor and Keith_McClary
hacivat said:
Summary:: Does the knob at the end of a telescopic antenna have a significance?
Both ... something easy to hold whilst extending the antenna and definitely to stop the inner tubes from disappearing inside
Likes Spinnor
Both, I should say. Lose the inner one down the inside and you may never get it back.
Tweezers and needle-nose pliers. Don't ask me how I know.
  • Haha
Likes berkeman, jim mcnamara, Keith_McClary and 2 others
It is also easier if you apply copious and creative swearing before you start in with the grasping tools.
  • Haha
Likes davenn and sophiecentaur
They were there long before the antenna became telescoping. Static dissipation. all the rest of the answers are also valid, but, now you know it's a there for a real function to the radio. A point would allow rapid discharge rather than slow bleed off. That rapid discharge would equate to noise and audio bursts inside the the radio.
Likes alantheastronomer
A ball or a capacity hat on a vertical whip transmitting antenna reduces corona discharge noise. The capacity hat also reduces the length of whip antenna needed for resonance.
The OP specifically referred to a radio receiver with a telescopic antenna. Static discharge is not a problem on receive because the antenna should be deliberately grounded through the front end of the receiver.
Likes coolul007
Related to Telescoping antenna -- why is there a knob on top?
1. Why does a telescoping antenna have a knob on top?
The knob on top of a telescoping antenna is used to adjust the length of the antenna. This allows you to tune in to different frequencies and improve the reception of your radio or TV.
2. Can I use the knob to adjust the reception of my antenna?
Yes, the knob on top of a telescoping antenna can be used to adjust the reception. By adjusting the length of the antenna, you can improve the signal and reduce interference.
3. How do I know how far to extend the telescoping antenna?
The length of the telescoping antenna depends on the frequency of the signal you are trying to receive. Generally, the higher the frequency, the shorter the antenna should be. You can consult the user manual or experiment with different lengths to find the best reception.
4. Is the knob on top of a telescoping antenna necessary?
Yes, the knob on top is an essential part of a telescoping antenna. It allows you to adjust the length of the antenna, which is crucial for receiving different frequencies and improving the signal.
5. Can I replace the knob on top of my telescoping antenna?
Yes, in most cases, the knob on top of a telescoping antenna can be replaced if it is damaged or lost. However, it is important to make sure the replacement knob is compatible with your antenna model.
