Temperature as a measure of thermal energy
In summary, temperature is a measure of the average kinetic energy per particle in an object, while thermal energy is the total internal kinetic energy of the object. Temperature does not directly measure thermal energy, but it is a crucial factor in determining it.
Mr Davis 97
1,462
44
I am little confused as to why temperature is a measure of thermal energy. Thermal energy is defined as the total internal kinetic energy of an object. Temperature, on the other hand, is defined as the measure of the average kinetic energy of an object, or the thermal energy per particle. If temperature only measures the average kinetic energy of each particle, then how does this measure thermal energy of an object, when there are other factors involved such as the size of the object. Say we have two containers of the same size. Container 1 has one particle moving at X m/s. Now imagine a second container. It as 10 particles moving at X m/s. Both of these containers have the same average internal kinetic energy, but container two has more internal kinetic energy. Could someone please explain why we use to temperature to measure thermal energy?
Science news on Phys.org
As you point out yourself, it's about the thermal energy per particle. If you have 10 particles instead of one, your denominator is also 10. If you have only one particle, you divide by just one. Either way, the energy per particle will be the same.
This is assuming you are disregarding the boxes themselves in that calculation. If you want to include them, you should for simplicity assume they are the same temperature as the particles they contain. In which case all you're doing is adding more particles to the denominator.
If the boxes are not the same temperature as the particles inside, well, the you'd be comparing apples with oranges, since the average temperature of the two boxes will differ.
We don't. Two objects with the same temperature can have vastly different thermal energies. Compare the thermal energies of a drop of water and the ocean, both at 20 degrees. Which one has more thermal energy?
FAQ: Temperature as a measure of thermal energy
What is temperature?
Temperature is a measure of the average kinetic energy of particles in a substance. In simpler terms, it is a measure of how fast the molecules in a substance are moving.
How is temperature measured?
Temperature is measured using a thermometer. The most common unit of measurement for temperature is degrees Celsius (°C) or degrees Fahrenheit (°F).
What is the relationship between temperature and thermal energy?
Temperature and thermal energy are directly proportional to each other. This means that as the temperature of a substance increases, so does its thermal energy and vice versa.
Can temperature be negative?
Yes, temperature can be negative. In fact, the absence of thermal energy is represented by 0 Kelvin (-273.15°C), which is considered as absolute zero.
How does temperature affect the physical properties of a substance?
Temperature has a significant impact on the physical properties of a substance. As temperature increases, most substances expand, become less dense, and change state (from solid to liquid to gas).
