Tennis ball speed after bounce
In summary: Dropping a ball from the same height but spinning at 0 rpm will result in less velocity after the bounce (the vertical component of velocity will increase with each bounce).
regor60
101
Can a tennis ball move faster immediately after it strikes the court than immediately before is the question
Thoughts ?
If you throw the ball up in the air with no forward velocity but significant spin, it will move once it rebounds. Seems to me that that, added to whatever velocity the ball had, would be additive, assuming spin and ball direction are aligned and no slip at the court surface. The most rotational energy transferred would be when the ball bounces with no residual spin. Conservation of momentum/energy and all that
If the rotational energy is greater than the loss of translational kinetic energy of the ball due to the impact with the ground, the ball could rebound with more translational kinetic energy than it had before the collision. But it won't be all upward, of course.
AM
In the case of a very elastic ball, more of the rotational energy could be transferred with the result of reverse spin after the bounce. I don't think a tennis ball has that much shear (spin) elasticity (most of the linear elasticiy is due to the compressed air inside the ball, the surface isn't that elastic). With an elastic ball, such as a super ball, a veritcal drop with spin on the ball will result in the ball alternating between a forwards bounce with reversed spin, and a veritcal bounce with nearly the original forwards spin (with height and spin decreasing on each bounce due to losses).
I think it is more a case of changing the direction of the velocity vector, rather than changing its magnitude.
Some numbers from cricket (tennis is for wimps!)
Mass of ball = 0.16 Kg
Radius = 0.036m
Considering the ball as a uniform solid sphere (which is not a bad approximation)
Moment of inertia = (2/5)(0.16)(0.036)^2 = 8.3 x 10^-5 Kg m^2
Measurements show that a world class spin bowler can bowl at about 27 m/s (60 mph) with the ball spinning at about 210 rad/s (2000 RPM)
Translational KE of ball = (0.16)(27)^2 / 2 = 58 J
Rotational KE of ball = (8.3 x 10^-5) (210)^2 / 2 = 1.8 J
So the idea of converting the rotational KE into more translational KE when the ball bounces is not going to have much effect.
But the relative velocity of the surface of the ball because of the spin, at the maximum distance from the rotation axis, is
(0.036)(210) = 7.5 m/s
which is significant compared with the 27 m/s velocity of the ball's CG, so the direction of travel before and after the first bounce, and the horizontal component of velocity (which is obviously an important factor in hitting or missing the ball) can be significantly different.
Radius = 0.036m
So as the angle of impact steepens horizontal component of velocity diminishes, meaning that the contribution of spin to horizontal speed after the bounce is proportionaly greater, right ? Hence just dropping a ball with zero horizontal speed but with spin, ball moves horizontally after bounce
Depends on the initial conditions (height versus spin). Dropping a ball from a height of 10 cm and spinning at 1000 rpm is going to result in more velocity after the bounce (the vertical component of velocity will decrease with each bounce).
Related to Tennis ball speed after bounce
1. How is the speed of a tennis ball after bounce determined?
The speed of a tennis ball after bounce is determined by several factors, including the initial speed of the ball before the bounce, the surface on which the ball bounces, and the angle at which the ball hits the surface. The laws of physics, specifically the conservation of energy and momentum, also play a role in determining the final speed of the ball.
2. Does the type of surface affect the speed of a tennis ball after bounce?
Yes, the type of surface can greatly affect the speed of a tennis ball after bounce. A harder surface, such as concrete or a hard court, will cause the ball to bounce faster than a softer surface, such as clay or a grass court. This is due to the surface's ability to absorb and return energy upon impact.
3. How does the angle of impact affect the speed of a tennis ball after bounce?
The angle of impact can have a significant impact on the speed of a tennis ball after bounce. When the ball hits the surface at a steeper angle, it will bounce off at a faster speed compared to when it hits at a shallower angle. This is because the ball has a greater velocity in the direction of the bounce when it hits at a steeper angle.
4. Can the speed of a tennis ball after bounce be calculated?
Yes, the speed of a tennis ball after bounce can be calculated using the laws of physics and specific equations, such as the conservation of energy and the coefficient of restitution. However, the calculation may vary depending on factors such as air resistance and the elasticity of the ball and surface.
5. How does air resistance affect the speed of a tennis ball after bounce?
Air resistance can have a significant impact on the speed of a tennis ball after bounce. As the ball travels through the air, it experiences air resistance which can slow down its speed. This can result in a slightly lower speed after bounce compared to the initial speed before the bounce.
  • Mechanics
