Tension and Normal Force in a Moving Elevator
In a scenario where a 5.0 kg mass is suspended in a decelerating elevator, the normal force is calculated as Fn=mg, resulting in 49 N. The elevator's upward motion is decreasing at a rate of 2.0 m/s², introducing an additional force due to negative acceleration. To find the tension in the string, the total force is calculated as f_total = 49 N - (5 kg * 2 m/s²), leading to a tension of 39 N. The approach combines the effects of gravity and the elevator's deceleration to determine the tension accurately. Understanding these forces is crucial for solving similar physics problems involving moving systems.
patelkey
A 5.0 kg mass is suspended by a string from the ceiling of an elevator that
is moving upward with a speed which is decreasing at a constant rate of 2.0
m/s in each second. What is the tension in the string supporting the mass?
-I know that the Normal Force on the string is Fn=mg so it would be equal to 49 N, however how would I use the rest of the information to calculate the tension in the string. I know that the answer is supposed to be 39 N but I don't know how to approach it from this point.
2.0 m/s/s means that there is an additional force caused by the deceleration of the elevator (negative acceleration), and F=ma. Therefore f_total = 49N - 5kg*(2m/s^2) = 39N
okk that's what I was thinking but I felt as if it was just a guess that happened to work out thanks for the explanation
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
