Tension Calculation for a Vibrating Violin String
To calculate the tension in a vibrating violin string, the relationship between the frequency of the sound wave in air and the string's frequency must be understood. The frequency in air, calculated as 857.5 Hz using the wave equation, is equal to the frequency of the string. The tension can be determined using the equation for the fundamental frequency of a string, f = (1/2L) * √(T/μ), where L is the length of the string and μ is the linear density. The challenge lies in confirming whether the calculated frequency corresponds to the fundamental frequency or a harmonic. Ultimately, understanding these relationships is crucial for accurately determining the tension in the string.
bigsaucy
A violinist places her finger so that the vibrating section of a 1.0g/m string has a length of 30cm, then she draws her bow across it. A listener nearby in a 20 degrees celcius room (speed of sound at this temperature in air is 343 m/s) hears a note with a wavelength of 40 cm. What is the tension in the string?
I was having real trouble with this question.
How are we meant to use the frequency of the wave in the air and transpose that information back into the string if we have no way of knowing the frequency/wavelength changes when the string hits the discontinuity of the medium (string-air)?
You are usually given problems which you can do. Look at what you have here: \mu = 10^{-3} \text{kg/m} You are given the speed of sound in air, you are given the wavelength and you are asked to find the tension in the string.
How can you relate these quantities?
Hello Greg.
I got the frequency in air to be 857.5 from the equation v = f lambda
Is the frequency of the sound wave in the air the same as the frequency in the string?
If yes, how is it that since some of the energy is transmitted to the the new medium (air in this case) and some transmitted back to the string, is the frequency the same?
The frequency doesn't change. Do you have an equation for frequency of standing waves on a string?
If i used f = 1/2L Sqrt (Tension/Linear Density) wouldn't I get the fundamental frequency? how are we meant to know if the frequency i calculated is the fundamental frequency?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
