Tension Problem (Two strings and an object)
  • Thread starter Thread starter AY3
    Strings Tension
A hemispherical sign with a diameter of 1m and a mass of 50kg is supported by two strings, leading to a tension calculation. The weight of the sign is determined using W = mg. To solve for the tensions in the strings, the equilibrium condition T1 + T2 - W = 0 is established, where T1 and T2 are the tensions in the strings. The torque equation is set up with respect to one of the strings, resulting in T1 = 166.67 N and T2 = 333.33 N. This approach effectively balances the forces and moments acting on the sign.
AY3
1. A hemispherical sign in 1m diameter and of mass equal to 50kg is supported by two strings. Calculate the tension in the strings.
2. W = mg
3. I tried to solve it but the only thing I was able to do is knowing the distance between the two strings which is 0.75m, I'm new to physics.
Hi AY3. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
Identify a point about which you can take moments.
Do I create an X and Y axes and then do the sin and cos with an angle of 90 degrees?
Placing an x and a y-axis on the diagram would be a good first step.
It doesn't matter exactly where you locate them.
I solved it, the first step was creating an equation for the summition of force. I called the strings T2 and T2, the equation is T1+T2-W=0 because the object is in equilibrium. I have two unknowns in the equation. So the next step is determining the torque, assuming the point of rotation is T2.
Its equation was (T1*0.75)–(W*0.25)=0
In the end T1=166.67n and by substituting in the first equation T2=333.33n
I meant T1 and T2.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
