Tension - pully problem w/ monkey
In summary, the conversation was about a diagram in a book showing a rope and a pulley problem involving a 15 kg box of bananas and a 10 kg monkey. The questions asked about the magnitude and direction of the monkey's acceleration needed to lift the box and the tension in the rope. The experts discussed the equations needed to solve for the unknowns and clarified the direction of acceleration for both the box and the monkey. The final answer for the acceleration was 1.96 m/s^2 and the tension in the rope was 117.6 N.
missrikku
tension - "pully" problem w/ monkey
Hello! The diagram in my book has a rope that is swung over a tree branch. Attached on one side is a 15 kg box of bananas and it is at rest on the ground. On the other side of the rope is a 10 kg monkey climbing up the rope. To me, this looks like a pully problem. Am I correct?
Then the questions are:
a) What is the magnitude of least acceleration the monkey must have if it is to lift the box off the ground? If after the box has been lifted, the monkey stops its climb and holds onto the rope, what are b) the magnitude and c) the direction of the monkey's acceleration, and d) what is the tension in the rope?
a) The "least acceleration" part confuses me. The box is just resting on the ground, so at the moment it has a = 0 m/s^2. So, wouldn't any acceleration on the monkey's part move the box up as long as we have Fmonkey > Fbox? I was thinking:
Fmonkey = T - mg = ma --> T = 10(a + 9.8)
Fbox = T - mg = ma --> T = 15(0 + 9.8) = 147N
So 10a + 98 = 147 --> a = 4.9 m/s^2
b and c) Okay, the box has been lifted and so the box and the monkey are hanging on the rope and are in the air. But then since the box has a greater mass than the monkey, the box starts to go downward and the monkey is accelerating upward? So, I think that the direction of the monkey's acceleration is upward. I know the direction, but I am lost as to the magnitude. The box has a greater mass than the monkey and since it is great enough to make the monkey accelerate upward as it falls down, I am thinking that Fbox > Fmonkey. But then, that is all I have understood. I am unsure of how to approach getting the magnitude of the monkey's acceleration upward.
d) I don't think I can get the tension of the rope until I have figured out b) :(
Thanks for your attention.
I agree with your acceleration for (a), and of course you're correct that in (b) the box accelerates downward & the monkey upward.
So now set up the same kind of equations for the situation where both masses are simply hanging on the two ends of the rope. Now T and a are unknown, so you have two equations and two unknowns. (Note that a is the same for both equations, and T is the same for both.) Solve & you get the answers for (b) and (d).
equations where the masses are simply hanging from the ropes?
I thought I had those two equations already?
T = 10a + 98
T = 15a + 147
10a + 98 = 15a + 147
a = -9.8
The answer in the example in the book says that the acceleration is supposed to be 2.0 m/s^2 and the T of the rope is supposed to be 120N.
With my two equations, I didn't get the same answer :(
Not exactly. You're confusing the direction of the acceleration. Remember, since they're attached, if you say that a is positive for the box accelerating downward, then a is positive for the monkey accelerating upward. I find it easier to see if I set the equations up in the same form as Newton:
∑F = ma
Now, for the box...
147-T = 15a
And for the monkey...
T-98 = 10a
You should get a=1.96 m/s^2 and T=117.6 N.
(Slightly different from the answers in your book. You and I were using 9.8 m/s^2 for g. Your book is rounding it to 10 m/s^2.)
By the way, it's PULLEY. :)
Yeah
That problem was on my quiz, I got the same answer. :smile:
Related to Tension - pully problem w/ monkey
1. What is a tension-pulley problem with a monkey?
A tension-pulley problem with a monkey is a physics problem that involves calculating the forces and motion involved in a system where a monkey is hanging from a rope that is attached to a pulley.
2. How do you solve a tension-pulley problem with a monkey?
To solve a tension-pulley problem with a monkey, you need to use the principles of Newton's laws of motion and apply them to the specific scenario. This involves identifying all the forces acting on the system and using equations to calculate the tension in the rope and the acceleration of the monkey.
3. What factors affect the tension in the rope in a tension-pulley problem with a monkey?
The tension in the rope in a tension-pulley problem with a monkey is affected by the mass of the monkey, the angle of the rope, and the acceleration of the monkey. It is also affected by the friction and weight of the pulley itself.
4. Can the monkey ever be in equilibrium in a tension-pulley problem?
Yes, the monkey can be in equilibrium in a tension-pulley problem if the forces acting on it are balanced. This means that the tension in the rope is equal to the weight of the monkey, and there is no acceleration.
5. How can a tension-pulley problem with a monkey be applied to real-life situations?
Tension-pulley problems with monkeys can be applied to real-life situations such as rock climbing, where a person is attached to a rope and pulley system. It can also be used to understand the mechanics of circus acts where performers are suspended from ropes and pulleys.
