Tensorflow checkpoints in training model
  • Thread starter BRN
In summary, the conversation discusses the implementation of a cycleGAN model and the related training process. The code includes the cycleGAN architecture, loss functions, optimizers, and a training session. The speaker mentions the use of Tensorflow checkpoints to train the model in multiple runs, but they are unsure of how to incorporate them as they have not used functions such as fit(), model(), or compile(). They are seeking assistance with this issue.
BRN
108
Hello everyone,
this is part of the code for a cycleGAN model that I have implemented, and it is the part related to training
Training cycleGAN:
# cycleGAN architecture
def cyclegan(input_A, input_B):
    # fake images generation
    BfromA = generateB(input_A, training = True)
    AfromB = generateA(input_B, training = True)
    # images recostruction
    regenAfromB = generateA(BfromA, training = True)
    regenBfromA = generateB(AfromB, training = True)
    # auto-generating
    gen_orig_A = generateA(input_A, training = True)
    gen_orig_B = generateB(input_B, training = True)
    # auto-validating
    valid_A = discriminateA(input_A, training = True)
    valid_B = discriminateB(input_B, training = True)
    # fake images validating
    valid_AfromB = discriminateA(AfromB, training = True)
    valid_BfromA = discriminateB(BfromA, training = True)
    return regenAfromB, regenBfromA, gen_orig_A, gen_orig_B, valid_A, valid_B, valid_AfromB, valid_BfromA
# Loss Functions - Optimizers
def generator_loss(generated):
    return tf.keras.losses.BinaryCrossentropy(from_logits = True, reduction=tf.keras.losses.Reduction.NONE)(tf.ones_like(generated), generated)
def discriminator_loss(real, generated):
    real_loss = tf.keras.losses.BinaryCrossentropy(from_logits = True, reduction=tf.keras.losses.Reduction.NONE)(tf.ones_like(real), real)
    generated_loss = tf.keras.losses.BinaryCrossentropy(from_logits = True,
                                                        reduction=tf.keras.losses.Reduction.NONE)(tf.zeros_like(generated), generated)
    total_disc_loss = real_loss + generated_loss
    return total_disc_loss
def cycle_loss(real, generated, LAMBDA):
    c_loss = tf.reduce_mean(tf.abs(real - generated))
    return LAMBDA * c_loss
def identity_loss(real, same, LAMBDA):
    i_loss = tf.reduce_mean(tf.abs(real - same))
    return LAMBDA * i_loss
#optimizers
gen_optimizer = tf.keras.optimizers.Adam(2e-4, beta_1 = 0.5)
disc_optimizer = tf.keras.optimizers.Adam(2e-4, beta_1 = 0.5)
# Training session
generateA = generator()
discriminateA = discriminator()
generateB = generator()
discriminateB = discriminator()
inputA = tf.keras.layers.Input(shape = [HEIGHT, WIDTH, CHANNEL])
inputB = tf.keras.layers.Input(shape = [HEIGHT, WIDTH, CHANNEL])
@tf.function
def train_step(inputA, inputB):
    with tf.GradientTape(persistent = True) as tape:
        regenA, regenB, gen_origA, gen_origB, disc_A, disc_B, disc_AfB, disc_BfA = cyclegan(inputA, inputB)
        A_gen_loss = generator_loss(disc_AfB)
        B_gen_loss = generator_loss(disc_BfA)
        total_cycle_loss = cycle_loss(inputA, regenA, LAMBDA) + cycle_loss(inputB, regenB, LAMBDA)
        A_identity_loss = identity_loss(inputA, gen_origA, LAMBDA)
        B_identity_loss = identity_loss(inputB, gen_origB, LAMBDA)
        total_A_gen_loss = A_gen_loss + total_cycle_loss + A_identity_loss
        total_B_gen_loss = B_gen_loss + total_cycle_loss + B_identity_loss
        A_disc_loss = discriminator_loss(disc_A, disc_AfB)
        B_disc_loss = discriminator_loss(disc_B, disc_BfA)
    # Gradients and optimizers
    A_generator_gradients = tape.gradient(total_A_gen_loss, generateA.trainable_variables)
    gen_optimizer.apply_gradients(zip(A_generator_gradients, generateA.trainable_variables))
    B_generator_gradients = tape.gradient(total_B_gen_loss, generateB.trainable_variables)
    gen_optimizer.apply_gradients(zip(B_generator_gradients, generateB.trainable_variables))
    A_discriminator_gradients = tape.gradient( A_disc_loss, discriminateA.trainable_variables)
    disc_optimizer.apply_gradients(zip(A_discriminator_gradients, discriminateA.trainable_variables))
    B_discriminator_gradients = tape.gradient(B_disc_loss, discriminateB.trainable_variables)
    disc_optimizer.apply_gradients(zip(B_discriminator_gradients, discriminateB.trainable_variables))
# Training
def train(train_ds, epochs):
    for epoch in range(epochs):
        start = time.time()
        print("Starting epoch", epoch + 1)
        for image_x, image_y in train_ds:
            train_step(image_x.numpy(), image_y.numpy())
        print('Time for epoch {} is {} sec'.format(epoch + 1, time.time() - start))
        save_step(input_path_A, sample_img, epoch, 'P', generateB, step_path)
I need to use Tensorflow checkpoints to train the model in multiple runs, but I have no idea how to incorporate them. I haven't used functions like fit(), model(), compile()...
Would anyone be able to help me?
Technology news on Phys.org
Hi there,
Tensorflow checkpoints are a useful tool for saving and restoring the state of your model during training. They allow you to save the weights and other parameters of your model at certain checkpoints, so that you can resume training from that point if needed.
To incorporate checkpoints into your code, you can use the tf.train.Checkpoint class. First, you need to define which variables you want to save as checkpoints. In your case, it looks like you would want to save the weights and other parameters of your generator and discriminator models. You can do this by creating an instance of the Checkpoint class and passing in the variables you want to save as arguments. For example:
checkpoint = tf.train.Checkpoint(generator=generateA,
discriminator=discriminateA)
You can repeat this process for your other models as well.
Next, you need to decide at which points during training you want to save the checkpoints. This is usually done at the end of each epoch, but you can also choose to save them at other intervals if needed. To save the checkpoint, you can call the save() method on your checkpoint object, passing in the path where you want to save the checkpoint. For example:
checkpoint.save("/path/to/checkpoint")
To restore a checkpoint, you can use the restore() method on your checkpoint object, passing in the path to the saved checkpoint. For example:
checkpoint.restore("/path/to/checkpoint")
You can also use the restore() method to load the weights and other parameters from a previous run if you need to resume training from a specific point.
I hope this helps! Let me know if you have any other questions.
FAQ: Tensorflow checkpoints in training model
How do I save and load TensorFlow checkpoints during training?
To save checkpoints during training in TensorFlow, you can use the ModelCheckpoint callback provided by the Keras API. This callback allows you to specify a directory where checkpoints should be saved and the frequency at which they should be saved. To load a checkpoint, you can use the tf.train.latest_checkpoint() function to retrieve the most recent checkpoint in a given directory.
What is the purpose of using TensorFlow checkpoints in model training?
TensorFlow checkpoints are used to save the current state of a model during training. They allow you to resume training from a specific point in case the training process is interrupted or to track the progress of the model over time. Checkpoints also enable you to save the best performing model based on certain metrics.
How often should I save TensorFlow checkpoints during model training?
The frequency of saving TensorFlow checkpoints during model training depends on the size of your dataset, the complexity of your model, and the computational resources available. It is common practice to save checkpoints at regular intervals, such as after every epoch or after a certain number of steps, to ensure that you have backup points to resume training from.
Can I use TensorFlow checkpoints to transfer a trained model to a different machine?
Yes, you can use TensorFlow checkpoints to transfer a trained model to a different machine. By saving checkpoints during training, you can easily move the model to another machine and load the checkpoints to continue training or make predictions. Make sure that the TensorFlow version and dependencies are consistent between the machines to avoid compatibility issues.
How do I monitor the performance of my model using TensorFlow checkpoints?
You can monitor the performance of your model using TensorFlow checkpoints by evaluating the model on a validation set after each checkpoint is saved. By saving the best performing checkpoint based on validation metrics, you can track the progress of your model and ensure that it is improving over time. Additionally, you can visualize training and validation metrics using tools like TensorBoard to gain insights into the model's performance.
