Testing Buffer Solutions with Cabbage Dye Indicator
  • Thread starter Thread starter pinky2468
    Buffer
A buffered solution maintains its pH when small amounts of acids or bases are added. After adding HCl, the pH 2 buffer is a buffered solution, while distilled water and NaCl are not. For NaOH additions, the pH 12 buffer can resist changes, while juice and soda are not effective buffers. Understanding the pH levels of HCl and NaOH is crucial for identifying which solutions can act as buffers. Clarifying these points can help resolve confusion regarding the lab question.
pinky2468
I am very stuck on this question and I am hoping someone can help me with this. We did this in lab and mine did not come out right, but I still have to turn it in and my lab teacher said to figure it out!
Buffer solutions using a cabbage dye indicator:
Which of these is a buffered solution after the addition of 5 drops of HCl, 10 drops HCl:
distilled water (I think no?)
0.1 M NaCl
pH 12 buffer
pH 2 buffer
Which if these is a buffered solution after 5 drops NaOH, 10 drops NaOH:
juice(pH around 4.5)
soda(pH around 3)
pH 12 buffer
pH 2 buffer
I know this is a loaded question, but I can't figure out which ones...HELP!
Chemistry news on Phys.org
Hi pinky, a buffer is a solution that contains a mixture of acids and bases.. if an acid or base is added to the solution the pH won't change. If you add a solution to a buffer outside it's buffering range, the buffer will loose it's power.
So thinking of that, which do you think the correct answer will be to your own question? Hint: what is the approximate pH of HCl and NaOH?
HCl is a pH 2 and NaOH is about pH-13-14 right? So, pH 2 is a buffer solution when HCl is added and not when NaOH is right? The rest I am still lost on!?
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
