Testing Faraday Cup for Electrostatic Charge Measurement
  • Thread starter Thread starter Weiber
    Faraday Testing
A homemade Faraday cup is being tested for measuring electrostatic charge in particles from a fluidized bed reactor, but it fails to maintain voltage after disconnection from the power source, losing potential within two seconds. The user is experiencing oscillations in charge measurements when connected to a picoammeter, suggesting possible construction issues or testing errors. Questions arise regarding the cup's construction, including whether it is shielded from electromagnetic radiation and if there are any high impedance leakage paths affecting performance. Suggestions for troubleshooting include examining the integrity of the standoffs and ensuring cleanliness. The discussion highlights the challenges of accurately measuring electrostatic charge with a DIY Faraday cup.
Weiber
Hello everyone. I am trying to use a Faraday cup constructed by myself to measure the electrostatic charge presence in particles of a fluidized bed reactor. I am trying to test if it works properly but I am having some problems.
I am tried to apply a voltage of 1.5 V till I obtain that voltage between the layers of the cup and then disconnecting it to see if it maintains that potential during some time, but when I disconnect the voltage source it looses the potential in like 2 seconds. Shouldn't it conserve the potential like a capacitor?
I have tried to measure the charge of particles connecting the faraday cup to a picoammeter, but when I collect the particles inside I obtain oscillations over and under the zero. Maybe it is not correctly constructed or I am testing it wrong.
Thank you so much for your attention. Regards!
It would be useful to know how it's constructed, is it shielded against EM radiation? Could there be a high impedance leakage path between the plates (could be grease/dirt on standoffs etc.)
-Chris
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
