Thanks again.Identification Algorithm for Parameter-Varying System?
The discussion centers on identifying parameters in a parameter-varying system using a model defined by differential and algebraic equations. The user has input and output measurements but faces challenges due to the complexity of the model, which involves 24 parameters derived from 8 expressions. Previous attempts with algorithms like least squares, gradient methods, and Newton-Raphson have been unsuccessful. The user seeks advice on effective identification algorithms suitable for this type of problem. Sharing the model is not possible due to restrictions, but insights on potential solutions are welcomed.
FaroukSchw
Hello everybody
I started recently working on an engineering problem that requires as a first step, the identification of the system.
I already have a model which is a set of differential and algerbraic equations. Unfortunatelly, the system is a parameter varying one, and the aime is to identify these parameters. Taking in consideration that i have input and output measurements, and about 20 parameter to identify.
Does anyone have an idea about an identification algorithm that can be used for such problem?
Regards.
It really doesn't make much sense to estimate the parameters of a time-varying system, unless you have the model for the time dependence of the parameters as well (periodicity, explicit functional form?) or you have some specific real-time application that I can't think off right now. Anyway, I'd really appreciate it if you'd share your models and tell us what you're trying to do
Hi elibj123
Thanks for taking time and responding to my thread.
In fact, i do have the expressions of the parameters, but since the model has 8 parameters, each parameter's expression contains three parameters, so 8*3=24 paameter to be identified.
The sensitivity of the model to the parameters varries from one parameter to an other.
I tried some algorithms such as different versions of the least squares, Gradient algo, Newton-Raphson, but they don't work!
Unfortunatelly, i can't share the model, because i don't have the right to, at least for the time beying.:frown:
I will be verry glad if you can provide some advices.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
