The angle grinder flange pair in UNF
  • Thread starter Thread starter abdulbadii
    Angle Pair
The discussion focuses on the availability of a grinder flange pair with a 3/8" x 24UNF thread, which is deemed unlikely to exist. Concerns are raised about the suitability of such a fine thread for large flange nuts, as it may lead to over-tightening and locking issues. Suggestions include using heat to remove jammed abrasive discs and exploring adaptors for M14 and M10 threads. A member proposes fabricating a spindle adaptor for a drill to function as a grinder, but notes potential limitations due to thrust bearings not handling radial loads effectively. Overall, the conversation emphasizes the challenges and considerations in modifying tools for different applications.
abdulbadii
TL;DR
is there's a grinder flange pair with thread 3/8" x 24UNF ?
Does anyone happen to know if there's a grinder flange pair, i.e. its spacer and fastener flanges, with 3/8" x 24UNF thread instead of M10 x 1.5?
If you have not found one yet, I think it is most unlikely.
Can you better describe exactly what you are trying to do?
24 TPI is a very fine thread for use on such a large flange nut, and it will almost certainly over-tighten in use and become locked solid. You will probably then break the locking mechanism while trying to undo the flange nut.
To remove a jammed abrasive disc from a grinder, heat the nut and disc with a flame. At about 150 °C, the polymer binder in the disc will collapse, so it can be undone easily.
Some adaptors are available for M14 and M10, to fit a 3-jaw chuck or an extender to an angle grinder. You might fabricate a similar adaptor for your application. Take care.
https://www.ebay.com.au/itm/394148756308
This one has a 3/8" UNF.
https://www.ebay.com.au/itm/374202960408
Need arose in making one of most common drill (here is mine) with 3/8" 24UNF shaft connector to function as grinder being able to use every kind of disc: cutting, grinding, wire disc, mounted straight onto it
You could keep the drill chuck with the drill and use the spindle from the second link I gave, or from a similar product.
Maybe you could thread the spindle adaptor to be 9/16" UNF, to eliminate the 3-jaw chuck.
There is a reason for the shape and speed of a regular grinder.
A drill will produce very different results.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 17 ·
16K
  • · Replies 54 ·
  • · Replies 80 ·
  • · Replies 31 ·
