The auto-ionization of H2O equilibrium
  • Thread starter Thread starter Roq
    Equilibrium
The discussion centers on the understanding of acid-base equilibria, particularly regarding strong acids like HCl. It highlights that while HCl dissociates completely to produce Cl- and H3O+, the equilibrium constant Kw remains crucial, especially at low concentrations. When HCl is at a concentration of 1x10^-7 M, the autoionization of water must be considered to accurately calculate pH, as it affects the concentrations of H+ and OH-. The conversation emphasizes that the relationship between H+ and OH- concentrations must account for Kw to achieve correct pH values, particularly in dilute solutions. Overall, the intricacies of acid-base equilibria and their calculations are essential for understanding pH in various scenarios.
Roq
I'm trying to conceptually understand a question that I was wondering about while reading about Acid and Base Equilibria.
Since a strong acid such as HCl completely reacts to give Cl- and the hydronium ion, and Cl- is then inert, then the only equilibrium going on is Kw. Kw = KbKa = [OH-][H+] = 1x10^-14...
I always thought that when OH- or H+ were produced, the Kw would balance itself like other reactions, and in this case it would mean the reaction going to the reactant direction.
Since the equilibrium would be restored by reacting [OH-] and [H+], they would both decrease on a one to one basis, and it could not just decrease the [OH-] without in turn decreasing [H+] at the same time.
That seems logical to me, but given the way these equations are calculated (at least in my class), like in the case of HCl, you would have an equal [HCl] and [H+] concentration, and there is no subtraction to account for the equilibrium of Kw. While this may not matter if you are dealing with 1 M of HCl, if your concentration is very small, like around 1x10^-7, then a large percentage of it would be subtracted as Kw is restored.
Perhaps it is irrelevant because there is little use for acids and bases at such tiny concentrations, but is this correct?
Chemistry news on Phys.org
If the concentration of HCl were 1X10^-7, the expression for Kw becomes:
Kw = [OH-][H+(from HCl) + H+(from autoionization)]
Let x = [H+(from autoionization)] We see that [OH-] must also be equal to x from the equation
HOH <---> H+(from autoionization) + OH-(from autoionization)
Substituting x into the Kw expression gives us:
Kw = x([H+](from HCl) + x)
Kw = x^2 + [H+](from HCl)x
0 = X^2 + [H+](from HCl)x - Kw
Solving this quadratic equation gives us x = 6.1803X10^-8. This is the new concentration for [OH-]. The total concentration for H+ is 1.62 X 10^-7. The pH is 6.79... slightly on the acid side as you would expect.
Kw does balance itself as in other reactions. If [H+] were 1M (pH=0), the concentration of [OH-] would become 1X10^-14. A pretty small number.
Thank you, guys.
Yes, in some cases, the auto-ionization of water is taken into account in finding the pH value, in the case of HCl, the pH is going to be accounted for by the extra "H+" that has been contributed by the HCl. With very small concentrations of HCl, Kw needs to be employed to obtain a significantly more accurate pH value.
  • · Replies 23 ·
