MHB The code should be:cout << secretID + spaceChar + lastName << endl;
  • Thread starter Thread starter ineedhelp420
The discussion centers on combining two strings in C++ to output "Barry Allen." The original code initializes two strings, `secretID` and `lastName`, and a character for space. To achieve the desired output, the correct approach involves using `push_back` for adding a character and `append` for adding a string. Specifically, `secretID.push_back(spaceChar)` adds a space, followed by `secretID.append(lastName)` to concatenate the last name. This distinction between `push_back`, which expects a character, and `append`, which expects a string, is crucial for correctly combining the strings.
ineedhelp420
Code:
#include <iostream>
#include <string>
using namespace std;
int main() {
   string secretID = "Barry";
   string lastName = "Allen";
   char spaceChar = ' ';
 /* Your solution goes here  */
   cout << secretID << endl;
   return 0;
I don't understand this. i need help
i'm suppose to out put "Barry Allen" but what do i push back?
Retype and correct the code provided to combine two strings separated by a space. Hint: What type of parameter does push_back expect?
Code:
   secretID.push_back(spaceChar);
   secretID.push_back(lastName);
Technology news on Phys.org
You can use the following code.
Code:
 secretID.append(lastName);
The [m]push_back[/m] method adds a character to the end of the line, while [m]append[/m] adds another string.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
