I The Correlation of Pressure and Torque in Rotational Motion
The pressure exerted on a screwdriver does not directly determine the torque during rotation; rather, it is the grip and friction that matter. Sufficient axial force is necessary to prevent the screwdriver from slipping out of the screw head, and this force depends on the torque and screw head profile. A worn screwdriver requires more axial force to achieve the same torque due to decreased effectiveness. The grip's tightness increases friction, which in turn enhances torque application. Ultimately, understanding torque performance relies more on force and friction than on pressure.
Robeurer
TL;DR Summary
Does pressure determine the magnitude of torque?
When you hold a screwdriver with your hand, a pressure is exerted on it. Does the pressure you exert determine the magnitude of torque in rotating the screwdriver?
No, only to the extent that you need to grip the screwdriver hard enough to not slip wheen you turn it.
Likes russ_watters
Depends what the grip looks like.
For a smooth solid of revolution grip, the pressure only determines the maximally possible torque, which comes from frictional forces.
But most grips don't look like that, so the local normal forces from pressure do have tangential components which contribute to axial torque.
Welcome to PF.
It is force, not pressure, that determines the performance of a screwdriver. Pressure is force per unit area. Area is not relevant to the forces that are applied while using a screwdriver.
You must apply sufficient axial force, to prevent the screwdriver from being rejected by, and disengaging from the screw head. The axial force required, will depend on the torque being applied, and the head profile of the screw. A worn screwdriver will require greater axial force to deliver the same torque.
You must apply sufficient radial grip force, to prevent the handle sliding with friction against your hand. Your grip of the handle limits the torque that can be applied.
Robeurer said:
TL;DR Summary: Does pressure determine the magnitude of torque?
The tighter your grip on the handle, the greater the friction force exerted on the handle. The greater the friction force the greater the torque. The concept of pressure is not needed to understand this.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
