The derivative of natural logs
In summary, the conversation is about the proper use of the substitution rule in integrating dy/(1-y). The person is making a mistake in their work and the others are trying to point out where the mistake is and explain the correct process. The correct answer is -LN |1-y|, and the negative sign comes from the substitution and the derivative of 1-y.
bobsmith76
336
I don't see why it's -LN it should be positive LN
never mind. it's the reciprocal rule in action. ln 1/x = -ln x
No, that's not the reason- there is no ln|1/1-y| involved. To integrate dy/(1- y), make the substitution u= 1- y. What is du? The - in the integral is because of the -y.
I don't follow you, if you use the substitution rule
u = 1 - y
du = -1
so then you have
du = -1dx
divide both sides by -1
du/-1, so when you integrate you would get 1/-y which is -LN |y| not -LN |1-y|
In any case, here is a similar problem:
both LN's should share the same sign. one should not be positive and the other negative.
u = 1 - y
du = -1
That's wrong. You can't have just one differential there.
so then you have
du = -1dx
How did x make an appearance here?
Show your work here. You seem to be jumping to conclusions and making mistakes.
the derivative of 1 - y is -1. what do you think it is?
whenever you take the derivative of a term I thought you always multiply it by dx
"Show your work here. You seem to be jumping to conclusions and making mistakes."
I did show my work. If you say I'm making a mistake then please point this out. It does me no good to say I'm making a mistake and not show how or why. Of course I know I'm wrong, I'm just trying to figure out how.
If u = 1 - y, then the derivative of u (with respect to y) is -1. That is correct.
What you're being told (and you seem to not understand) is that if du/dy = -1 , then
du = -dy​
There's no x involved. no differential stands alone on one side of the equation w/o there being a differential on the other side.
It's hard to show you where you're making mistakes if you don't clearly show what you did. We can't read your mind, and we can only guess what you did if you don't show every step.
From what you've written, this is what I have so far. You start with
$$\int \frac{dy}{1-y}$$ Now you let u=1-y, then got dx = du/-1. That's what I assume you meant when you wrote, "du/-1". Then you continued, "so when you integrate you would get 1/-y", by which I took to mean you claim
$$-\int \frac{du}{u} = \frac{1}{-y},$$ which is wrong. How did you get that? Then somehow turned that into "-LN |y|". How did you do that?
Or perhaps you didn't really integrate when you said you did. Instead, after doing the substitution, you arbitrarily turned all the u's back into y's and said
$$-\int \frac{du}{u} = -\int \frac{dy}{y} = -\ln |y|$$
The derivative of ln x = |1/x|
If we use u substitution then dy/(1-y) = dy/u
When we take the derivative of dy I think dy (I'm still not sure, I find the notation of derivatives very confusing) becomes 1, so we have
1/u or 1u-1
Now, I don't know what to do because if I integrate 1/u that will give ln u or ln |1-y|, not
-ln |1-y|
I still don't understand where the negative comes from.
I'm still lost on this one.
With ##u=1-y##, it follows that ##y=1-u##.
Taking the derivative on both sides, we get ##dy=-du##.
Substituting, we replace ##(1-y)## by ##u##, and ##dy## by ##-du##.
So:
$$\int {dy \over 1-y} = \int {-du \over u} = -\ln |u| + C$$
Now we can back substitute ##u=1-y##, giving:
$$\int {dy \over 1-y} = -\ln |u| + C = -\ln |1-y| + C$$
thanks, now I got it.
FAQ: The derivative of natural logs
What is the derivative of ln(x)?
The derivative of ln(x) is 1/x.
How do you find the derivative of ln(u), where u is a function of x?
The derivative of ln(u) is equal to u'(x)/u(x). In other words, you take the derivative of the function inside the natural log and divide it by the original function.
Can the derivative of ln(x) be negative?
Yes, the derivative of ln(x) can be negative. This occurs when x is between 0 and 1, making the value of 1/x negative.
What is the derivative of ln(x^2)?
The derivative of ln(x^2) is equal to 2/x.
Is the derivative of ln(x) the same as the derivative of log(x)?
Yes, the derivative of ln(x) and log(x) are the same. Both represent the logarithmic function with base e, also known as the natural logarithm.
