The Doppler Effect: Deducing an Expression for Frequency
The discussion focuses on deriving an expression for the frequency heard by a listener as a sound source moves perpendicularly away from them. The Doppler effect is central to the problem, with the initial equation provided being fl = fs(v/(v-vs)). Participants are attempting to incorporate the distance L into the equation, with suggestions to consider the velocity component of the source relative to the listener. The conversation highlights the need to analyze the source's velocity at each moment in time to accurately reflect its impact on the frequency perceived by the listener. The goal is to find a way to integrate L into the frequency calculation effectively.
jono90one
A sound source moves at a constant velocity. A listener is standing at a distance L away from it. Given that the source moves in a straight line at a right angle to the listener and starts closest to the listener (ie at t=0) deduce an expression for the frequency heard by the listener in relation to time.
fl=fs(v/(v-vs))
where l is listener and s is source
It's obviously Doppler effect related.
So far I’ve done T=1/fs
And gotten
fl=v/T(v-vs)
But unsure how to get L into the equation.
Surely VT is the distance traveled by the wave and vsT is λs. Is there any orientation where L can be introduced? Or is this version correct?
take in the velocity component of the source away from the observer at each instant of time in the governing equation.
(edit) So you mean f=v/T(vs-v)??
No
O(t=0)----------------------->vt(point A)(source)
|L
Point B(you)
I want you to find the component of source’s(A) velocity
Along the line joining point A & point B at an instant t
And plug that velocity into your equation for vs.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
