The doppler radar trap paradox on the path to gravity.
In summary, the police man fires a low wattage continuous wave radar gun at a craft passing him and measures the crafts speed with a beat frequency that he measures with the incoming and outgoing waves. The craft is made of a superconductor and acts as a perfect mirror, so the police man can measure the crafts speed accurately. The police man's original calculation of the crafts speed was incorrect because the photons have energy and the craft's distance from the reflector was 1.7329 meters.
andrewr
263
Hello All,
I have been challenged by a friend to look into Gravitational waves and some questions he has about them -- but I have always been a slow starter. Took physics with SR in college, got my BSEE, happily can build analog circuitry of all kinds -- but found that certain questions about SR never did get answered by the Prof and have gnawed at me ever since. Now I accept SR by and large -- but don't really accept GR yet -- so gravity waves are still in the Poincaire electrical charge theory realm (and Feynman had some speculation too, if I remember correctly) for me. And I figure, I best resolve the simple issues first before tackling the bigger ones ... a physics oriented crowd has perhaps studied some experiment that I haven't and might already know which of a set of answers is a dead end... hopefully this thread will grow in knowledge and build toward my friends questions -- which intrigue me, and I hope -- you.
So here is a simple gedanken with inertial frames to begin the journey toward gravity. I am not good with Minowski 4 vectors, so -- if you don't use them thanks! -- but if you do, please be very clear what they mean.
I am envisioning a radar trap with a policeman. We can ignore the rotation of the Earth and gravity here. I am also envisioning a craft passing the policeman at c/2. Since we are with the policeman at the moment, he is our inertial frame. The craft is another inertial frame -- not accelerating nor decelerating. There is sufficient rest mass with both the policeman and the craft so that the radar gun he fires at the craft does not change the speed between them measurably.
Please correct any assertion that is clearly contradictory:
1. Since there are only two objects -- the policeman and the craft -- the speed measured by one ought to be the same as the speed observed by the other. There is no third body issue.
2. The policeman is firing a low wattage continuous wave radar gun. Eg: let's say 300MHz in his frame -- and he is aiming it at the craft passing him. At T=0 the craft is touching the gun, and thereafter it recedes directly away from the gun at a constant velocity V.
3. Older radar guns work on the Doppler effect (red shift/blue shift). Our police man is using one -- eg: Essentially, he is measuring the beat frequency of his outgoing wave with the incoming one -- and using that to determine the crafts speed. The craft -- for its part -- is made of a superconductor, and is acting as a perfect mirror nicely aimed to give the policeman an accurate reading.
4. Einstein believed in "photons" and the photoelectric effect. Hence, we may view (consistently for his thinking) the police man as ejecting photons with wavelength 1 meter, frequency 300Mhz (assuming c=3x10**8 exactly, otherwise -- scale accordingly for nice math.).
5. Using my old EE books on radiation, by Dr. Aziz Inan -- we can view this as a simplification of Maxwell's equation. We can treat the outgoing and reflected waves as a plane wave in the x direction. The boundary condition is that the perfect conductior has no E-field inside it (charge neutral superconductor) and its location is x=v*t. The resulting TE (transverse electric) then is zero at x=vt. When I solve Maxwell's equations this way, I arrive at a standing wave. The returning wave has the same amplitude as the outgoing one, and is 100MHz.
Now; Here's where my choose your poison/paradox/irritation begins.
I naively thought, since the original wave had a length 1M in the policeman's reference frame -- in the crafts frame it ought to have one of 1M / L, where L=sqrt( 1- v**2/c**2). Now that is clearly wrong. When I find the second place away from the reflector where no E-field exists by Maxwell's equations -- I come to the conclusion it is at 1.5Meters from the reflector in the police frame. now 1.5Meters/L = 1.7329Meter'.
Where the ' means the craft's meter stick. That answer looks right.
So, here's the first question: Since Einstein viewed photons as having energy E=hf; What is the proper way to balance Energy for a *single* photon? Upon reflection from a lossless mirror which has sufficient rest mass such that acceleration is negligible -- Maxwell's equations predict the reflected wave will have a lower frequency in the police man's reference frame. eg: the photon lost energy upon a lossless mirror. The loss depends on the velocity of the mirror, and nothing else.
In the reference frame of the craft -- the light does not know who (police or craft) is moving -- so being a good mirror -- the light is reflected and is the same color to the observer on the craft. ergo: No energy loss. The perspectives are at odds to each other -- so rather than believe the police unconditionally -- tear these to shreds:
1. proposition: Photons do not really have E=hf energy each -- that is just the energy they release to an electron during a reaction ejecting an electron from a photoconductor. Actual photons may have FRACTIONAL amounts more or less than hf.
2. proposition. Photons are not really individual (a variation of 1) -- if we take the extra time delay from when a the police gun is shut off to when the last of the light arrives back at the gun -- we will find that the lower energy returning photons last for just enough extra time that a the energy (assuming a CW wave and ignoring photons) balances out. Low power x longer time = higher powe x shorter time. (In fact it does balance out.)
3. What would you propose that completely explains the reconciling of the policeman's view -- and the crafts view?
welcome to PF,
Adjust the frequency.
Before jumping to conclusions concerning quantum physics and relativity, make sure you understand and resolve the exact same contradiction that arises in classical mechanics. Use perfectly elastic rubber balls, bouncing from a moving surface. In one frame, they don't lose energy. In another, they do. Where did the energy go?
(Hint: the velocity of the wall will change, and the effect of that change is not negligible.)
The lost energy goes into increased KE of the mirror. If you are neglecting the acceleration then you are also neglecting the change in energy. There is nothing wrong with that since it is a small effect, but neglecting one object's change in KE and then finding that energy is not conserved is hardly paradoxical.
No, they are not at odds to each other. The photon's energy decreases in all inertial frames and the mirror's KE increases in all inertial frames. Again, purposely neglecting something does not make for a paradox.
None of these are needed. There is no paradox here to resolve, just an accounting error.
No. KE is frame dependent, and does not transform linearly.
D'oh! You are right. In frames where the mirror is traveling towards the photon the KE of the mirror decreases and the energy of the photon increases! Of course, energy is still conserved in all frames, but the amount and direction of the energy transfer is frame dependent.
Ich said:
welcome to PF,Adjust the frequency.
If the wall were free, yes its velocity would change.
I accept most of your answer -- although I find it quite unsettling for the kinds of things I am exploring -- and am not sure it really applies. (My fault for not noticing the obvious?)
BTW: I am not trying to disprove SR in favor of "classical physics" -- and mentioning that the same problem exists in classical physics doesn't really solve my problem -- it doubles it.
It is exactly this kind of assumption that I am often forced to make in EM calculations, for say -- transmission lines. A shorted transmission line does *NOT* transmit any energy beyond the short -- nor does the short adsorb any energy. All energy is reflected at the short circuit.
Or again...
If the wall, or mirror, were, say -- the end of the universe (a transmission line which is "open" so to speak) -- the energy loss would still exist, although no energy could transmit beyond the edge...
In that case -- as in the case of a mirror -- 100% reflection would still occur. (The sign of the reflection would simply change from inverted to non-inverted.). The experimenter can not know whether his photon hits the edge of the universe or not -- so, this seems to imply, that an assumption is made every time a physics equation is calculated about the nature of the reflector. (It was my intent to avoid the assumption if possible -- and that is also the reason I tried to avoid any third body issues/calculations where a rest mass was concerned.)
Your solution requires an assumption that I am trying to pin down the meaning of. I am beginning to think it is elusive because something is swept under the rug in my EE classes (so to speak.).
So, to be perhaps hair splitting:
In a frame of reference where the wall is NOT moving, one does not say "the wall accelerates" and that "acceleration is not negligible". I see it commonly stated/assumed that a wall does not accelerate, and the velocity change is in fact ignored. ERGO: the energy of the ball is conserved and the wall gains and looses no energy -- the way (I presumed) this was known, is that the wall does not accelerate. But now, I am thinking, it is simply that the WALL's frame of reference is preferred -- because the mathematics becomes subject to roundoff error, otherwise...
Given a transmission line (an exact analogy to the mirror and the police-man with a SINGLE frequency CW signal -- eg: non-dispersive) where a reflector moves along the transmission line with time -- lengthening it by exposing more of it (a sliding short with exposed conductors) -- as an EE I would view it as mathematically identical to the photon/speed trap problem. According to all calculations (and the poynting vector) -- 100% of the energy *IS* reflected at the mirror/short.
Now, has anyone seen a case where the force on such a short circuit is shown to be non-zero?
(superconducting transmission line and short circuit.)? My gut reaction, having just toyed with the equations, is that the poynting vector shows 100% energy reflection at the superconducting short circuit. ( Perhaps I have made a mistake...? )
If not, is there a difference when computing photons vs. an EM wave on a transmission line?
What is this difference?
To be clear: I am not in favor of classical physics over SR -- I am trying to grasp where the assumptions fail -- and *why*. -- see possibility 3. I am a slow starter, as I said.
Ich said:
welcome to PF,
Not to be asanine, but since I am after a subtle point -- I wish to make sure we're comparing like to like by enforcing a bit of narrow mindedness.
Here's a simple analysis of your classical problem.
Correspondence principle -- nonrelativistic speeds:
Initially, from the frame of reference of the ball, the wall is approaching at a given velocity v.
After impact the wall recedes at the same velocity. The magnitude of the wall's velocity as measured from the ball is constant w/ a sign change, ergo the energy which is related to the *square* of that speed as mass does not change classicly with speed. eg: m*v**2 = m*(-v)**2: eg: even In the limit as mass approaches infinite, the equation is exactly balanced such that regardless of the mass of the wall and the ball -- the approach speed and the leaving speed are identical and opposite. Therefore, energy is *always* conserved -- strictly. Momentum is a different issue, but I was not considering momentum in my original problem either. The magnitude of momentum is clearly conserved as well -- but the direction is not.
In any elastic collision between two masses, the relative speed (the only physically measurable speed) in a strict two body problem -- is conserved regardless of the individual masses. The ball and the wall may be considered inertial before and after the collision, with the non-inertial consideration limited to a point discontinuity.
From the perspective of the wall, the exact same is true. No imbalance in the conservation of energy is detected. Even if the wall is not infinitely massive, and the attraction between ball and wall are known -- working the problem out from either reference frame will produce the same result classically.
No paradox is noted.
I do see that if I choose a third reference frame, the mass of the wall must be known in order to solve the problem, and that (in that case which I purposely avoided) the wall becomes important as a sink of energy.
So, it would seem, that even a photon of light must indroduce a three body problem, even though the photon has zero rest mass in SR -- and the "Ether" is supposedly irrelevant as a reference frame.
Energy of a photon, then, still must be an incomplete description of that photon, then, somehow.
Hmm...BTW. Thanks for the welcome -- I'm glad to find people actually interested in thinking a bit.
You are really over-analyzing this, there is nothing complicated here.
Just write down the expression for the initial momentum of your mirror for some arbitrary velocity and write down the expression for the initial momentum of your light pulse. You know the mirror's velocity so you know the Doppler shift of the light pulse and therefore the change in energy and momentum for the light.
Use conservation of momentum to determine the mirror's new velocity and then you can check to make sure that energy is conserved for any arbitrary mirror velocity.
Btw, you might be interested in the http://en.wikipedia.org/wiki/Four-momentum" , which I find to be one of the most useful concepts of SR.
Ηi Dale!
A paradox is an apparent (even if illusionary) contradiction. The twin paradox is a paradox precisely because when looked at in the way presented -- it does not have a solution unless further information is used to break they symmetry. eg: one person "feels" the acceleration... etc. I don't mean to imply that there is no solution to the problem I am presenting -- I mean that it causes certain irritations because assumptions in EM waves class leads to the paradox, and it is NOT self evident how to resolve the paradox to me -- I expect there is a solution.
The issue I am having probably centers around the idea of instantaneous action at a distance.
I defined the problem simply as a starting point of a discussion, not as an all encapsulating description of an irrefutable contradiction. Please see my posts to the German "I" ;) not, I hope, a synonym for the greek Ego. ηγω.
OK. Let me then, push the wave/maxwell equation for a moment. If, as you say, the energy is transferred to the mirror -- then why is it that the time average power computed for the returning wave EXACTLY balances out?
A quick and crude calculation I emailed to a friend is attached:
My question to you, is that since the wave equation (not the photon based one) predicts all energy is in fact returned -- how is it that you say the mirror is necessarily accelerated?
Also, the problem EXPLICITLY sets the location of the mirror to x=vt; therefore, the form of the solution which follows (missing only a scalar constant to match it in terms of volts/meter) ought to take into account the fact that the mirror does not accelerate. What you appear to argue, then, is that something is wrong with Maxwell's equation -- for I asked the question thusly: given a wave which hits a mirror that is NOT accelerating, what wave must return in order to solve Maxwell's equation.
I would have expected the solution to take into account any implied forces or masses which prevent the mirror from accelerating. The problem is: since the mirror does NOT accelerate, and the returning wave from a NON accelerating mirror is a wave with lower energy -- why do you insist that the mirror "must" have accelerated. (This kind of thinking is irritating, and I apologize -- I am doing this as an exercise to get to the bottom of a certain issue that cropped up from my EM classes. But realize, that if there is a counterbalancing force which prevented the acceleration -- I am fishing for why Maxwell's equation does not compensate for that -- and if Maxwell's equation DID -- why is it that the reflected wave does not appear to agree with a wave packet/photon type of approach.)
;------------------------- quick and crude calculation --------------------------
Assume a mirror which at t=0 is touching a microwave antenna. It is
moving away from the antenna at velocity v (a constant), the antenna is
radiating source energy of radian frequency "ωs" at the mirror.
... and of course, the speed of light is just 'c'.
In this case, one can set up a standing wave equation, satisfying
Maxwell's eqns. And knowing 100% reflection occurs:
Efield = cos( ωs - ωs/c * x ) + cos( ωr + ωr/c * x + α )
Knowing that the E-field is 0 inside a conductor (eg: the mirror), and
that the mirror is moving with velocity v, the above equation is zero at
x = v*t; e.g. the mirror. The answer pops out:
ωr = ωs * (c - v)/(c + v). for example, if v=c/2, and ωs = 2*π*300Mhz
(wavlength=1Meter) the returning frequency ωr = ωs*(.5/1.5) = ωs*(1/3).
So, to the observer standing at the transmitter, the photons coming back
have 1/3 the energy (2/3'rds lost!).
However, when one works out how long until the light stops returning,
assuming the transmiter turned off after T seconds (the mirror being T*v
meters away):
The distance the mirror travels until the last of the wave hits it:
v*T + v*Td = c*Td
So, Td = v/(c-v)*T
The total time, then, is the "on" time + last of outward going light
making a round trip.
T + 2*Td:
So the total time receiving is just: T + T*2*v/(c-v)
= T * ( c + v )/( c - v).
The equation is scaled exactly opposite to the loss of energy.
loss of energy scalar = (c-v)/(c+v)
gain of time scalar = (c+v)/(c-v)
multiply together, answer is 1. Therefore, energy is conserved.
QED.
If the mirror does not accelerate then your mirror/light system cannot be isolated and whatever external force is keeping it from accelerating can transfer energy to or from the system. So again, no problem.
If you neglect something (either the acceleration of the mirror or the external force preventing it from accelerating) then obviously you can get these accounting errors you are worried about.
Dale,
Energy is conserved in Maxwell's equation -- if energy is dissipated any OTHER way maxwells equation is WRONG.
Maxwell's eqations, I was taught, are correct on *average* -- eg: an expectation value.
If so, then all the energy is accounted for in the wave itself. NO ENERGY IS REQUIRED ANYWHERE ELSE. It does NOT flow around the mirror, or any other way in the problem I have set up.
Do you have any proof that the energy MUST flow around it somehow?
Again: It balances according to Maxwell's equations but NOT when individual photons are imagined.
Why do these complemetary methods predict different things must be happening?
I admit there is an error, but can you show what the error is such that MAXWELLS equations do not say that all the power is reflected back -- or the converse, that in the case of photons -- all energy must be reflected back. One of these two is required for the equation to balance.
The mirror does not have to be isolated, and I never claimed it was. I simply claimed that it was not accelerating.
A la Maxwell. Take an coaxial cable, stationary in the lab frame. As you assume, one end is shorted and at the other end, you inject a signal. With all the energy reflected from the end, the cable contains a standing wave.
In an inertial frame in relative motion parallel with the length of the cable, the observer will no longer see a cable containing standing waves. As he travels down the cable he will see alternating nodes and antinodes. The transmitted and reflected signal are no longer equal in frequency. The reflected energy is not equal to the transmitted energy per E=hw.
In an inertial frame in relative motion parallel with the length of the cable, the observer will no longer see a cable containing standing waves. He sees beats on the cable. The transmitted and reflected signal are no longer equal in frequency. The reflected energy is not equal to the transmitted energy.
In the example problem I gave, the policeman sees either 1: A 300MHz outgoing wave CW -- and a 100MHz returning wave CW -- (if they are separated spatially by say a double reflecting 90' mirror or two coaxes side by side) -- or else he sees the superposition of a 100Mhz and 300Mhz wave -- which has standing and traveling components. It is correct that he sees a modulated wave. The modulation is has null spots every 0.75Meter, and repeats. The modulated envelope travels with and is stationary to the reflecting mirror -- which means that the modulation moves TOWARD the mirror in the police man's frame (AKA lab frame.).
Since the mirror/short is moving, the length of the cable is effectively changing with time -- it is effectively becoming longer. The result is, that should one turn the source off at any time -- the power will still be reflected back for a certain period of time AFTER the transmitter is turned off. (The mirror continues to move with the same velocity). This length of time happens to exactly balance the the change in power reflected -- eg:
power transmited*transmission time = power reflected * (transmission time + delay until coax is empty of radiation)..
See the above analysis.
Power is not conserverd, but total energy is.
Please be direct.
andrewr said:
since the wave equation (not the photon based one) predicts all energy is in fact returned -- how is it that you say the mirror is necessarily accelerated? [...waffle...] realize, that if there is a counterbalancing force which prevented the acceleration -- I am fishing for why Maxwell's equation does not compensate for that -- and if Maxwell's equation DID -- why is it that the reflected wave does not appear to agree with a wave packet/photon type of approach.
andrewr said:
Again: It balances according to Maxwell's equations but NOT when individual photons are imagined[..]?
OK, so you have a mirror that does not accelerate. As you point out, if we reflect a classical EM wave against the mirror, the reflected beam will have lost zero energy (and its wavelength will be unchanged, although its momentum has been reversed). Similarly (as you may not have realized), if we bounce photons of a mirror that does not accelerate then the photons (at least on average) will also not lose any energy.
Why doesn't it accelerate, when in both cases there is obviously a force against one side of the mirror? There must be a balancing force on the other side. Perhaps a symmetric EM wave (or sequence of photons) on the other side. Perhaps a free mass bounces bounces off of a spring that is attached to the mirror's other side (conserving its energy but changing its momentum to balance the light's). Perhaps the mirror has a rocket engine (converting chemical energy to kinetic energy of the exhaust which again balances the light's momentum).
Conversely, if the mirror was isolated then the mirror will be accelerated and the light will lose energy, regardless of whether you consider individual photons or a classical EM wave.
What do you mean by this?
It doesn't matter if you use Maxwell's equations or photons, the result is the same. The light (Maxwell or photons) has momentum which is approximately reversed by the reflection. Conservation of momentum requires the mirror to accelerate (or an external force to act on it). Any energy missing from the light is accounted for by the mirror's acceleration or the force on the mirror.
Reasonable sounding, but still missing the target.
Have you ever heard of the ultraviolet catastrophe? It is a mis-prediction based on Maxwell's equation. (the wave equation as opposed the schrodinger diffusion equation.). There is all kinds of extra energy predicted that doesn't exist by the Raleigh Jean Law. Plank is the one who remedied it. So, I tend to think it does matter. Plank did not derive his result from Maxwell's equations -- he assumed them empirically. Now I don't remember all the details... but, that's part of why I am trying to work this out.
The thing is, if Maxwell's equation says that for a given frequency reflected by a superconducting mirror will reflect *all* the energy -- albeit, at a lower frequency(/ies) and a longer duration -- and that exactly balances out, so there is no reason to require extra energy going around the outside as far as I can tell.
The problem which does *seem* to exist, is that quantum mechanics requires photons -- when detected -- to be found only in one place and to have fixed energy. They are not *smeared* out like maxwell's equation would seem to require.
Consider: a wave packet, and perhaps a number of sine waves, having the energy of an emitted quantum at 300Mhz -- and a wavelength roughly constant -- when reflected. The mobile mirror stretches the returning wave out in both time and space. The duration of the packet is longer and its amplitude is smaller. When one adds up the components of the reflected photon, they add up to the energy of the *original* photon.
No matter what the composition of sine waves of the original packet, the mirror would reflect them linearly stretched in time and space. Longer times, wavelengths, and lower frequencies.
Now photons of *different* frequencies do not have the same energy -- so an *apparent* contradiction may exist -- here's why:
If it were always something nice like -- the reflected frequecy is 1/3 -- then I could say that three photons of the lower energy existed where only one was before. But the thing is, any velocity is permitted in relativity and it doesn't necessarily work out to a nice number of photon multiplications.
Secondly, from quantum mechanics, there is the issue of the wave packet. A photon, when it is detected, is detected in only one place. I can only imagine one thing is happening at the mirror when non-nice fractions are set in place by the velocity chosen:
If a single photon hit the mirror and all the energy was reflected back -- it must split into two photons -- one with more energy, and one with less. Yet, that would suggest one can detect a low freqency wave which directly coincides with the higher frequency wave. It would be as if extra energy were present in the photon (since they coincide). However, in the other reference frame (that of the mirror) only a single photon would ever be detected by any conceivable experiment. (correction: any photoelectric effect experiment which Einstein uses).
I don't see anything (and I may be blind) in Maxwell's equation which would correspond to this energy splitting. The original packet did not have multiple photons (as we can trace a single one which must split), and the scaled reflection I would expect to have exactly the same composition with a smaller amplitude as the original -- just stretched out in time and space.
There is no need to *add* energy -- but to reconcile how Maxwell's equation and photons relate to each other. E=hf would seem to require a modification of some kind to maxwell's to correctly identify when photons split (if they do) -- and how much energy to expect in the localized place a photon exists in.
Maxwell's equation already accounts for all the energy when NOT using wave packets.
If there is any extra unbalanced energy going around the "outside" of the experiment -- it is not because of Maxwell equations predictions.
When I try to add the refinement of the wave packet/quantized photons -- then I have a hard time reconciling where the energy went.
Just curious about the name -- a Battlestar Galactica fan?
I want to address what you bring up in a bit more detail -- perhaps it will help stimulate some new thought.
The change of reference frame issue is something I find important -- but also a bit of a false attractor of criticism. According to texts I have read (not analyzed thoroughly) Maxwell's equations are already corrected for relativity (Einstein/Infield).
There is an issue when traveling along the cable (as you note) where energy "looks" different.
The issue though, is whether there is a difference in ability to change/interact.
What I mean is this -- I am looking for reconciliation where computations of an interaction in one frame of reference predict the same chain of events (even though translated through a transform) from a different frame of reference. That is, I want two different observers to say that all events detected in one frame -- are also detected in the other -- just transformed by a predictable amount.
Now, to the energy accounting problem:
I am working the original problem out in the lab/(police man) frame -- but noting what happens in the mirror frame as well -- as a sanity check. Using a coax cable as an analogy (with certain defects about propagation speed and invariance not being exactly the same) -- gives *qualitative* ideas about what would happen in the limit where the cable is removed. eg: we are guaranteed that 100% reflection occurs. Therefore 100% of the energy transmitted is returned. The forum member, Ich, noticed that as well -- and rightly pointed out the reference frame issue.
When I have a problem with Energy, though, it is *NOT* from different frames of reference -- but rather from the same frame of reference. The energy transmitted by the police man is reflected back to him/her. Now, I gave Ich a rather narrow minded analysis of the classical case, to show that (as perverted as it might seem) -- riding along with a ball in an elastic collision (assuming we survived the impact!) would not cause the observer on the ball to note a violation of conservation of Energy.
(momentum is a different issue.) I would kind of hope Ich would continue the conversation as that member appears to have a pretty good grasp of physical/mathematical relationships.
The thing that is interesting is that there is no accounting error in the picture I gave of the classic system -- it is just a fact of life that when using the ball's reference frame -- which is a translation of a "third" observer's frame who watches two balls collide externally -- that momentum reverses sign for any mass that the observer may believe the wall (or ball) to have. There is NO violation of conservation of momentum going on. It is just exceedingly difficult to realize that from the reference frame of the ball. Conservation of energy is easy to show. However, there is no violaton of either the momentum or the Energy law -- even though momentum appears to be violated (until one includes the momentum of the ball they are riding on which I omitted)
Dalespam wants to wash the energy issue away by claiming it "leaks" around the outside. Perhaps, if there is a mathematical reason that conservation of energy predicted by the increased time of flight (doppler effect) predicted by delay line & relativity -- I would be interested in indulging Dale.
My simple analysis goes like this: In classical mechanics, F=ma -- and work (energy) = force(net) x distance.
If two equal and opposite forces act on each other -- the net force is zero -- and no work (energy) is done/transferred. How can one tell no work was done? Because there is no acceleration. F=ma.
That is a sufficient condition (classically) to claim, that in the experiment (which is defined with velocity=constant, acceleration=0) that no energy is being transferred to the mirror. (For whatever physical reason).
--continues in a moment ---
-- continued --
I suppose, it is possible that mass already moving at exactly the same velocity as the mirror could be added to the mirror. But that doesn't in any way affect the fact that Maxwell predicts no energy supply to the mirror; in and of iteself (perhaps I have a mistake in the analysis.).
What I do see, is that maxwell's predicts points of minimum standing (as in standing wave) energy located a short distance away from the mirror and moving relative to it. Eg: 1.5 meters as measured by the meter stick of the police man -- so that would be 1.7320meter to a person measuring it in the mirror's reference frame.
Now, I don't have my relativity book handy -- but that (I suppose) is the doppler shift that has been corrected for lorentz contraction for a 300MHz source wave. (Anyone second that opinon/correct me?).
A second problem which crops up -- is that the naive solution to maxwell's equation using Dr. Inan's simplification of a plane wave soluton -- meets the boundary conditions, but...
Maxwell's equations have energy which scales as the square of the magnitude of the E field. (Read voltage for a transmission line with metallic conductors). If I plug that in directly, all the sudden energy is created -- Eg: there is no increase in power with frequency in maxwell's equations -- only with voltage/magnetic field or E&B-field. But since the energy/meter (average) is the same for the outgoing and reflected wave -- a longer return time=more energy. Fortunately, the crude calculation I gave earlier is NOT the only possible solution -- and my alternate way predicts a balance in energy as expected.
(This energy imbalance goes the wrong way for DaleSpam's idea -- more energy comes BACK to the police man than left.)
This is one of the main issues I am trying to solve. How does the E and B fields translate into more energy as frequency increases, and why.
So far, I have a solution which agrees with doppler shift in both frames of reference -- it creates a standing wave in the reference frame of the mirror. But there is something missing.All the solutions offered so far sort of suggest/hint at the same thing -- certain frames of reference are incapable of balancing energy & momentum.
I was hoping that in each frame, although the values of energy are different, within a single frame -- energy could be balanced.
Ok; I'll put up a bit of info I found in my advanced EE text.
Apparently, in 1837, Maxwell predicted that EM waves carried momentum.
From Electromagnetic Waves, Umran S. Inan & Azis S. Inan.
pp. 76: Radiation pressure by definition is the force per unit unit area exerted by a wave upon a material it is incident on.
ΔP = Sav * ΔA * Δt / c
Where Sav is the power from a Poynting vector calculation which gives us watts/meter**2
The result is that according to maxwell, momentum = Power * time / c;
or to be more obvious: p = E/c.
So, the balance of momentum attempted to be transferred is 2*p (to the mirror) since the photon is reflected and not adsorbed. (Inan verfies this on pp.77).
I still don't know what you mean by the "outside" of the experiment or "leaking" as you said in other posts. In any case, there is no basic discrepancy between the photon or Maxwell description here, nor is there any even apparent paradox here, just stubborn accounting errors on your part.
Let's consider the following scenario and carefully account for the energy and momentum:
Without loss of generality we will use units where the speed of light is 1 and the vacuum permitivity is also 1. Consider a brief pulse of light traveling through free space initially in the -x direction towards a perfect mirror located at the origin. The mirror is equipped with a stabilizer which will provide any force necessary to prevent it from accelerating. The pulse is timed such that the center of the pulse reaches the mirror at t=0. For purposes of the Maxwell description this pulse of light will be a rectangular pulse of unit amplitude and unit duration with the E field of the pulse pointing in the -y direction. For purposes of the photon description the pulse will be a single photon with unit energy. We will examine the situation in the reference frame described above and also in the primed reference frame where the mirror is moving in the positive x' direction at 0.6 c.
Photon approach:
The initial four-momentum is
p0 = (1,-1,0,0)
The final four-momentum is
p1 = (1,1,0,0)
The change in four-momentum is
dp = (0,2,0,0)
By conservation of four-momentum the stabilizer must provide an impulse of
ps = (0,2,0,0)
which does no work. This is consistent with the fact that the KE of the mirror is unchanged and the energy of both the incident and reflected photons are equal.
Maxwell approach:
The E-field of the incoming pulse is (0,-1,0) as defined above and therefore the B-field is (0,0,1) in our units. The energy density is (E.E)/2 + (B.B)/2 = 1 and since the pulse is of unit duration it is also of unit length. Therefore, integrating over all space we get that the pulse has total energy of 1. The momentum density is ExB, and so integrating over all space gives a total initial momentum of (-1,0,0).
The E-field of the outgoing pulse is (0,1,0) and the B-field is (0,0,1). The total energy is again 1, but the total final momentum is (1,0,0).
The change in energy is
de = 0
The change in momentum is
dp = (2,0,0)
So by conservation of momentum the impulse provided by the stabilizer must also be
ps = (2,0,0)
Since the impulse acts over a unit time the force required is
f = dp/dt = (2,0,0)
The mirror does not move so the work done by the stabilizer is
w = f.d = 0. This is again consistent with the fact that the KE of the mirror is unchanged and that the energy of the reflected and incident pulse are equal. This also agrees with the photon description above.
We will now examine the situation in the primed frame where the mirror is moving in the positive x direction at a speed of 0.6 c which corresponds to a time dilation factor of γ = 1.25. The Doppler shift at that speed is a factor of 2.
Photon approach:
The initial four-momentum is redshifted by a factor of 2
p0' = (0.5,-0.5,0,0)
The final four-momentum is blueshifted by a factor of 2
p1' = (2,2,0,0)
The change in four-momentum is therefore
dp' = (1.5,2.5,0,0)
ps' = (1.5,2.5,0,0)
which does 1.5 units of work. This is consistent with the fact that the KE of the mirror is unchanged and the energy of the reflected photon is higher, corresponding to a blueshift. All of the energy supplied by the stabilizer goes into the reflected photon.
Maxwell approach:
Because of the Doppler effect the E-field of the incoming pulse is (0,-0.5,0) and the B-field is (0,0,0.5). The energy density is (E.E)/2 + (B.B)/2 = 0.25 and due to the Doppler shift the pulse is of duration 2 and length 2. Therefore, integrating over all space we get that the incoming pulse has total energy of 0.5. The momentum density is ExB, and so integrating over all space gives a total initial momentum of (-0.5,0,0).
The E-field of the outgoing pulse is (0,2,0) and the B-field is (0,0,2). The energy density is 4 and due to the Doppler shift the pulse is of length 0.5. The total energy is therefore 2, and the total final momentum is (2,0,0).
The change in the energy of the light pulse is
de' = 1.5
The change in the momentum of the light pulse is
dp' = (2.5,0,0)
ps' = (2.5,0,0)
Since the impulse acts over a time of 1.25 the force required is
f = dp'/dt' = (2,0,0)
The mirror moves over a distance of 0.75 so the work done by the stabilizer is
w = f.d = 1.5. This is again consistent with the fact that the KE of the mirror is unchanged and that the energy of the reflected pulse is greater than the energy of the incident pulse by 1.5. This also agrees with the photon description above.
So you see, there is no mystery about the energy and the momentum in either frame using either approach. Everything agrees completely and both energy and momentum are properly conserved in each frame using each method.
Dale, the very fact that you use a square wave -- whose frequency is unknown -- means you haven't a clue about the setup of the problem I am posing. The error I am speaking about comes from the fact that an item with a strict frequency is a sinusoidal source (CW). Such a source has sinusoidal E and H components. Yes, they are in phase, as you show in your square wave pulse -- but they are sine-waves. When we speak of E=hf, or hν, we are talking about a nearly strict frequency.
A forward and reverse traveling wave are computed such that the boundary condition of perfect reflection occurs at the mirror. ( E field = 0; B field may be nonzero ). There may be other boundary conditions associated with the derivatives found in Maxwell's equations.
We need to know the waveform before reflection and after reflection *in the same frame* in order to check energy conservation. (If I don't get an exact balance, that's O.K., but surely more than 50% of the Energy better show up!)
As to the big deal you are making about the momentum transfer...
A Nichols radiometer shows quite conclusively that radiation pressure is quite small.
If I shine a 10W (10 Joule/second) laser on a silvered mirror attached to a small RC car motor -- there will not be enough force to turn the motor let alone generate even 1/2 watt in a vacuum.
I have never seen an equation which says radiation pressure INCREASED as something ran away from light -- in fact, I rather think it decreases. So the error you seem worried about ought to be LESS than that of a mirror which is NOT moving.
(Air is a different matter...) There is no need to worry about energy/momentum being transferred by light to the mirror as the "loss" I am speaking of.
A policeman typically uses a radar gun with less than 1KW of power... *much less*
So, let's say 1400 watts/m**2 to be conservative. (Enough warm up lots of things...)
In that case, the radiation pressure would be: 4.67 x 10**-6 N/m**2. A *VERY* tiny pressure indeed.
Of the Energy arriving, only 1 part in c (3x10**8), is turned into a Newton/meter**2.
A mirror weighing, say, 1kg total, and being 1Meter**2, (from rest) would accelerate at 9.1 micro meters/second **2.
The energy adsorbed by it's acceleration would be less than (classic works fine here...) E(joules) = 1/2 * 1Kg * ((1 x 10**-5) * t)**2
In other words, for a 1 second experiment (which is plenty long to get the results I am after),
the energy loss from a 1000+ watt * 1 second = 1,000 Joule energy transfer -- would be less than a nano Joule.
Just curious,
Now, what will be the waveshape of the returning rectangular pulse you calculated? How long will the pulse be (duration) -- and how large an E and B field? What boundary conditions did you use with Maxwell's equations to arrive at that?
Read http://www.fourmilab.ch/etexts/einstein/specrel/www/" :
A.E. said:
It is remarkable that the energy and the frequency of a light complex vary with the state of motion of the observer in accordance with the same law.
That should reconcile the alleged photon/Maxwell discrepancy.
Another point: If you transfer a small momentum to an object at rest, you won't significantly change its energy. That's different for a moving object. If you try to follow that reasoning, use inertial frames for the calculations.
A square wave can easily be decomposed into a sum of CW sinusoids with Fourier analysis (sinc function in frequency domain) if you feel it is important, and since Maxwell's equations are linear the principle of superposition applies. Also, by the Heisenberg uncertainty principle a photon does not have a single energy (frequency) nor a definite duration, they have some finite natural linewidth. Thus a pulse with a spread of frequencies, such as what I proposed, is a much better classical representation of a photon than a CW sinusoid. Also, a CW sinusoid, by itself, has infinite energy which a photon does not, which is another reason that a CW is not a good approximation of a photon.
The waveforms both before and after reflection are rectangular pulses (f(x) = A if |x|<w/2, 0 otherwise), the incident pulse traveling towards (f(x+ct)) and the reflected pulse traveling away (f(x-ct)) from the mirror. The pulse widths (w) and amplitudes (A) are given above. You can easily check that the waves satisfy Maxwell's equations for free space plus the usual reflecting boundary condition.
andrewr, you are making irrelevant objections. If you wish to remain confused that is certainly your choice, but your question has been conclusively answered several times now. There appears to be nothing more I can do for you.
I think there was nothing you could do in the first place except to try and exchange one problem for a different one.
I don't think you know how to solve Maxwell's equations. ( or don't care to do the hard parts ).
A rectangular pulse reflected off of a moving target has a different length. Why isn't that in your square pulse response?
(you don't actually want to work out the whole problem?)
If A CW wave of a given frequency has "infinite energy" -- it only has finite power. That power *will* be the same as many photons overlapping and having their wave patterns merged. I solve QM problems for silicon that way -- I see no reason why it can't apply here where dispersion is not a problem.
No, unfortuneately it doesn't. Einstein isn't comparing a sinusoidal wave against E=hf when he does the problem. I have no way of comparing amplitudes and duration with that method.
Thanks, though, it is interesting.
Let me shift this argument a bit -- by first going over the relativity and frame arguments.
I will note that it isn't proper to make the second frame "free floating" as it wasn't in my original problem -- but I think there may be enough information here to at least track down some of the issues I am facing.
--more--
I am glad that the relativistic Doppler shift was included in that link -- it verifies the wavelength I computed for the reflection using Maxwell's equations.
Since the lab frame uses the relativistic formula twice over, that also verifies that a 300MHz
transmitted wave will become a 100MHz reflected wave as predicted.
Perhaps, then, if you think I am focusing on the problem wrong -- let me lay out some points, and you tell me which is wrong and shown by any experiment. I'll stick to the relativity first -- and we can build on that step by step. (It may be enough by itself.)
E = hν
When transmitted, and transmission is at 300MHz, a *single* photon at that frequency has:
Eph = ~6.63 x 10**-34 Joules/Hz * 300MHz = ~198.9 x 10**-27 Joules
Since Maxwell predicts a momentum transfer of p=2E/c for a *totally* reflected photon;
The max momentum we are talking about must be Pph = 2 * 198.9 x 10**-27 Joules / 3.0 x 10**8 m/s
Or simply: Pph ~= 1.326 x 10**-33 Newton*seconds or kg*m/s for each photon
Since the lab frame and mirror are the only two reference frames in the experiment I don't think it possible that they would measure/calculate the velocity between them that is different from each other. That is, can the lab frame measure a velocity which is different from the mirror frame? Or will they *necessarily* agree on how fast they move apart?
(I think it is the latter, but I am asking the question -- is there an ether -- I am holding no.)
Given that they can *not* measure different speeds, then it would follow that any event that happens in one frame to accelerate it would necessarily be registered in the other frame as a velocity change. That velocity will be agreed to by BOTH frames.
Ok, then let's examine a police man with a reflector at rest to his frame first. The rest frame of the police man is so massive ( a million Kg or infinite), that no velocity change can be detected for the number of photons involved. Yet we ignore gravity... (You can rework these assumptions if they make a difference -- but gravity is not part of SRT's domain.)
A 1 photon packet is released and reflected. The mirror accelerates, and both the police man and the reflector register the same velocity change. The velocity is non-relatavistic, and we may use correspondence principle.
The momentum carried by a single photon of 300Mhz light is:
p = 2 * 198.9 x 10**-27 Joules / 3.0 x 10**8 m/s = 1.326 * 10**-33m/s.
In classical physics, momentum / mass = velocity; so: 1Kg --> 1.326 * 10**-33 m/s
But, in general, E = 1/2*m*v**2 would give: 0.5 * 1Kg * ( (Eph/c) / 1Kg ) **2
Or, 0.5 * Eph**2 / m0
From which it is clear that the larger the mass of the mirror, the less energy is transferred by a photon reflection off a mirror. The result is a function of the photon Energy**2.
Thus, I would expect LESS energy to be transferred as the velocity of the mirror increased as well.
Eg: In the frame of reference that the photon is emitted in, the mirror which is moving must have more mass.
If this is wrong -- let it go for now, and we will ascertain the correct/falsity a little bit later.
I am after the rest frame balance first.
So:
Whatever velocity change is registered in the moving mirror frame must *also* register in the stationary police frame -- and it must be identical.
For conservation of energy to hold, the energy NOT returned in a photon must exactly be offset by the amount which the other body adsorbs. Otherwise we have a creation or deletion of energy.
So, since the mirror gains KE from rest, where KE = m0*c**2*( γ - 1 )
And ... The reflected photon must have Eref = Eph - KE = initial energy - transferred energy
But we only have momentum of the photon to work with from Maxwell, so translating momentum into KE is done this way:
(TE=total energy of object)
KE = TE - m0*c**2
KE = sqrt( p**2 * c**2 + m0**2 * c**4 ) - m0*c**2
Since the momentum gained is: 2*Eph/c according to Maxwell:
KE = sqrt( 4 * Eph**2 / c**2 * c**2 + m0**2 * c**4 ) - m0*c**2
KE = m0*c**2 * ( sqrt( 4 * Eph**2 / (m0**2*c**4) + 1 ) - 1 )
Which by inspection of the original KE = m0*c**2*( γ - 1 ) , means that:
γ = sqrt( 4*Eph**2 / (m0**2 * c**4) + 1 )
calling: α = m0*c**2
1/sqrt( 1 - (v/c)**2 ) = sqrt( 4*Eph**2 / α**2 + 1 )
1/( 1 - (v/c)**2 ) = 4*Eph**2 / α**2 + 1
1 - (v/c)**2 = 1 / ( 4*Eph**2 / α**2 + 1 )
(v/c)**2 = 1 - 1 / ( 4*Eph**2 / α**2 + 1 )
(v/c)**2 = ( 4*Eph**2 / α**2 + 1 - 1 ) / ( 4*Eph**2 / α**2 + 1 )
(v/c)**2 = ( 4*Eph**2 / α**2 ) / ( 4*Eph**2 / α**2 + 1 )
v**2/c**2 = ( 4*Eph**2 ) / ( 4*Eph**2 + α**2 )
v**2 = c**2 * ( 4*Eph**2 ) / ( 4*Eph**2 + α**2 )
v**2 = c**2 / ( 1 + α**2/(4*Eph**2) )
v = c / sqrt( 1 + 0.25*(α/Eph)**2 ) )
v = 1/sqrt( 1/c**2 + 0.25*(m0*c**2/Eph)**2/c**2 )
v = 1/sqrt( 1/c**2 + (m0*c/(Eph*2) )**2 )
This agrees qualitatively with the classical formula. As the mass becomes larger, the velocity drops & energy transfer drops.
v ~= 1.326 * 10**-33
KE( mirror ) ~= m0*c**2*( γ-1.0) = 879.138 * 10**-69 Joules.
Photon return energy ~= 198.9 x 10**-27 Joules - 879.138 * 10**-69 Joules
Δf=( Eph - KE )/h - 300MHz = -1.326 x 10**-33 Hz.
Δf=((c - v)/(c + v) - 1)*f0= -2.652x10**-33 Hz.
I carried the math out to 1000 decimal places and rounded off only in the answers I wrote down. I kept around 20 significant digits.
bc under Linux is awesome!
Do you see any mistakes in this analysis so far?
If so, would you kindly point them out?
From the relativity values, I have computed:
1) The velocity of the Mirror and its KE.
2) The energy of the recoil photon as Eph - KE.
3) The frequency of the recoil photon from two ways
a) from relativistic Doppler shift formula based on the velocity and source frequency,
b) from the recoil Energy (conservation of energy argument) and E=hf.
The frequency does not match. Doppler shift and relativity seem to be a bit odd.
It is if you had bothered to actually read:
Maxwell approach:
Now you are the one changing the problem. In any case the correct answer is the same, but you have to state everything in terms of power instead of energy.
A radiation of a given power exerts a given pressure on a mirror which is equal to the change in momentum of the light over a unit time. To keep your mirror from accelerating this requires a constant force. In the rest frame of the mirror this force does no work, consistent with the fact that the frequency of the incoming and outgoing waves are the same and their power is the same. In a frame where the mirror is moving towards the light that force does work, this is consistent with the fact that the frequency of the outgoing waves are blueshifted and their power is higher. No missing power.
Sorry, I don't understand. Einstein shows immediately before §8 how classical amplitudes transform, and in §8 derives E=const.*f for a classical wave packet. He proposed the photon idea three months before, so it's clear that he identifies it with a fundamental "light complex". His comment I quoted before, "It is remarkable that the energy and the frequency of a light complex vary with the state of motion of the observer in accordance with the same law", shows his satisfaction that the classical approach is fully consistent with the photon view.
Now I'll do the energy calculations in both frames. I regard the limit where the photon energy is very small compared to the mass of the wall.
In the wall's frame:
[tex]E_{in}=E_{out}=hf \sqrt{\frac{1-v}{1+v}}[/tex]
[tex]\Delta E_{photon} = \Delta E_{wall} = 0[/tex]
The change of the wall's energy goes to zero compared with the photon energy.
In the emitter/receiver frame:
[tex]E_{in}=hf[/tex]
[tex]E_{out}=hf \frac{1-v}{1+v}[/tex]
[tex]\Delta E_{photon} = -hf(1-\frac{1-v}{1+v})=-hf \frac{2v}{1+v}[/tex]
The transferred momentum is accordingly
[tex]\Delta p = (E_{in} +E_{out})/c=hf \frac{2}{c(1+v)}[/tex]
The change in the wall's Energy is
[tex]\Delta E_{wall} = \frac{\partial E_{wall}}{\partial p} \Delta p = E_{wall}/p \Delta p = v \Delta p = hf \frac{2v}{1+v}[/tex]
So the wall gains exactly the energy that the photon loses.
Yeah, I didn't read that carefully. I hit apparent mistakes early and quit.
Let me understand what you mean.
(ellipsis mine).
DaleSpam said:
Maxwell approach:
de = 0
In this part of maxwell's eqn, you do not show (even under the ...) the reflected wave but claim the energy change is zero. I agree.
Photon approach:
p1' = (2,2,0,0)
dp' = (1.5,2.5,0,0)
ps' = (1.5,2.5,0,0)
Why this is red and then blue shifted I have no idea. The mirror is moving APART, so the doppler shift would red-shift twice. The frame of reference would first be the police, then a lower f at the receding mirror, and then lower yet when returning to the original frame.
The non-relativistic Doppler shift is f0*(c-v)/(c+v) -- and that is the square of the relatavistic formula showing a double red shift. Ich shows that correctly in his post.
I asked in an early post that if you used the minkowski type objects, that you be very clear what they mean -- as in why. Is this blue shift you speak of found only in four vectors?
This next section is the one I overlooked -- as I did not see in the original section on maxwell the expanded waveform.
Maxwell approach:
O.K.
I don't follow this.
When you solved Maxwell's equation, what boundary conditions did you use in order to compute the amplitude of the returning wave. Did you do them with respect to the derivatives, or just the amplitude. Eg: in a transmission line with a non-moving termination, voltage and current continuity across the short is what results in reflection. Derivatives are ignored as the short isn't moving.
How did you get that answer?
Again, there is no sine wave. Please do it with a cosine wave or a wave packet (sinc pulse) if you prefer. I'd like to see your boundary conditions when you solve the wave equation and how the amplitude of the individual sine waves translate.
No, I did not change the problem. You did. Mine was based on a sine wave which can be checked for boundary conditions using Maxwell's equations. For your solution to work, you would need to show how E field cancels at the location of the mirror. A square wave with different amplitudes on a boundary does not cancel, so there is an E-field at the mirror.
A sine wave has an amplitude which goes to zero at certain points, and when the waveform is modulated can produce a solution which has different forward and backward waves -- esp. if the argument is nonlinear in time -- something that the standard wave solutions do not take into consideration.
What were your boundary conditions?
Those might solve my problem as I have questions about the proper ones -- !
Again. In my original problem:
1. the mirror was traveling away -- so there is double redshift.
2. I used a sinewave source.
Neither of these did you do in your problem.
Also; if you are now trying to say that the problem can't be done with individual photons -- assign a wave packet to them -- then you appear to invoke the wave particle duality paradox. I am going to laugh at you if , in telling me that what I am doing is not a paradox at the start of the thread by invoking another paradox. Of COURSE quantum particles can violate conservation of energy - ... - for a short time.
  • #31
Hmmm... perhaps if you had told me to read the section before §8 I would have read it.
I'll go look.
In your workup -- you end up simply assigning the energy change to the proper item.
On cursory glance, I don't see two different ways of calculating the Energy so that E=hf can be compared -- but perhaps I missed something.
When I attempted the purely relativistic approach, above, for a free mirror -- as I understood you wanted me to do that -- I do not arrive at the same energy change when using the photon calculation from energy only consideration vs. Doppler shift.
Do you see a mistake in my attempt someplace? (I do not, and suspect I might have one -- though it baffles me.).
I'll read the section you mention on Einstein previous to the section I was told to read before -- but if he is using a "classic" wave packet, the fact that all sine waves in a wave packet will stretch linearly still makes me think I will be forced to do some kind of fixup that splits photons with Maxwell's equations and E=hν in order for it to work.
Thanks, Ich, I really appreciate the help.
I'll answer your post in detail a bit later when I have a chance to adsorb it more.
  • #32
Oh, and Dale, I most certainly HAVE been talking about power all along.
v*T + v*Td = c*Td
So, Td = v/(c-v)*T
T + 2*Td:
QED.
And to show that I am averaging photons over time for power, note:
andrewr said:
Since the mirror/short is moving, the length of the cable is effectively changing with time -- it is effectively becoming longer. The result is, that should one turn the source off at any time -- the power will still be reflected back for a certain period of time AFTER the transmitter is turned off. (The mirror continues to move with the same velocity). This length of time happens to exactly balance the the change inpower reflected -- eg:
Power is not conserved, but total energy is.
A delay line, which space is, has capacitance and inductance per distance. These capacitance and inductance elements are NOT carried along with the energy. They are not Ether. So, The energy one pours into any differential element actually exists at that point (whatever that point is philosophically). When a perfect reflector is modeled in Maxwell's equations, and it moves, what is happening is that more differential elements of inductance and capacitance are being exposed. There is *no* "motion" of these elements, as there is no ether. On average, when doing the idealized calculation for a transmission line -- the energy must spread out *in some way* to fill the extra space -- eg: energy storage capacitance and inductance per unit length. From experiments done in the lab with a fast 'scope and a movable short -- done multiple times to cancel noise -- I am pretty certain that a moving short does not adsorb any more energy than a stationary one. -- even if the short is made to change position by oscillation in the low MHz region -- which is the fastest I can make it move.
I am not doing all of this, here, to grind some pet theory -- I am trying to reconcile experiment with maxwell's equation and relativity *both*.
I hope by doing this, I will be able to begin to understand the general theory of relativity and a particularly tricky problem that has been presented to me.
  • #33
Yes. I see in section §7 what you are speaking about, now that I have read that section too.
For all practical purposes in this discussion, we are speaking about the simplified φ=0 in the 1905 document.
As a side note; Einstein does not appear to do a derivation from Maxwell. He does *not* convert the amplitude of the field -- rather he does the conversion of A**2. When one works with Maxwell's equations, one does not have A**2 as part of the wave equation.
I don't know how to convert to A**2 in Maxwell's equation, as the square of the individual components of the wave equation can-not be squared independently without changing the character of the equation -- and the meaning of the boundary conditions.
This doesn't really help me understand what is going on as an Engineering student familiar with Maxwell's equations -- which is most of the point of doing the exercise, and why am am somewhat lost here.
Yes, but he transformed the intensity**2 in the first place, which is identified with energy ?
If the transformation truly predicted the change of energy with frequency, then he ought to have been able to derive plank's constant -- for E=m*c**2, links the other terms together, giving a scale.
I am not aware of Plank's constant being derivable from the speed of light; so I tend to wonder if the coincidence has to do with the way he transformed amplitude squared in the first place. Or else, it may be that we shall have an exact value for the constant soon in terms of c...
That may well be -- I just wish he had done it from the classical equation!
It also makes me wonder why my calculation came out with two different answers using the principle equations that are taught in college physics courses including relativity, which I took. They did not do the four vectors, but only the way momentum and energy and mass are related -- and I understand that well enough to be able to at least make calculations. (even though they don't agree with E=hf based on the values I have).
I'll get to your analysis here in just a bit ... I haven't quite got everything straight in my mind.
  • #34
I am sorry that you are finding it confusing. The information is there, but because I was having to work the same problem 4 different ways I necessarily did a very sketchy outline and expected the readers to fill in the details. I gave the formula for energy density (E.E)/2 + (B.B)/2. When you integrate energy density over space, as I mentioned in the next sentence, then you get energy of the incident pulse. Then I did the same for the reflected pulse. Since they got the same energy the difference in energy is obviously 0.
This is not a big deal. I worked the problem with the mirror going into the light so that the stabilizer would do work. It is a simple matter to reverse the sign of the velocity, get the mirror moving in the opposite direction, and have work be done on the stabilizer. However, in that case it would be blueshifted and then redshifted by my usage.
Remember, I am starting with the reference frame where the mirror is at rest, this is my base reference frame. In that frame there is no Doppler shift from the reflection, the radiation is the same base frequency on the incident and the reflected wave. (note that this is not necessarily the same frequency as that emitted by the source of the wave since I never specified the source's velocity). If the mirror moves away from the incident light pulse (-x' direction) in the primed frame frame then in the mirror's frame the primed frame is moving towards the incident pulse (+x direction). Thus the initial blueshift if I reversed the sign of the velocity. If you are defining the "base" frequency as the frequency of the source rather than the frequency in the mirror's frame that is fine too and depending on the source's velocity in the primed frame you could get either a redshift or a blueshift. It is not an important detail as long as everyone is clear about what they are doing, I hope this clarifies what I did.
I posted a link to the Wikipedia page on four-momentum earlier. It is a very useful concept. It is a vector formed by (E/c, px, py, pz) where E is the total energy (rest+kinetic) of the particle, px is the particle's momentum in the x direction and so on. The conservation of four-momentum embodies in one nice neat package the classical principles of conservation of energy and momentum. The four-momentum transforms like any other four-vector, which makes it particularly convenient to work with for problems like this.
If n is a unit vector normal to the surface of the conductor then the usual boundary conditions for a stationary conductor are nxE=0 and n.B=0 on the surface of the conductor. You can verify that the sum of the incident and reflected pulses satisfy this boundary condition at x=0 in the unprimed frame.
I am not interested in doing that, it is a really unimportant detail that doesn't change any of the points that I have made (due to the linearity of Maxwell's equations) and serves only to unnecessarily complicate the math. The amplitudes transform by the Doppler factor, if you have a redshift of 2 then your amplitude is half and your duration and length are doubled. If you want more details about how the electric and magnetic fields transform see the last set of equations in section 6 of Einstein's paper that Ich linked to earlier.
In the mirror's frame the electric field has the same amplitude and opposite direction and therefore cancels at the mirror. This satisfies the boundary conditions.
I don't know how you would possibly come to that conclusion when I worked the problem in both frames using individual photons. I even put them in sections that I clearly labeled "Photon approach". All I said is that a continuous sine wave is a very poor classical approximation to a single photon. A rectangular pulse is not only mathematically more convenient, but is also a much better analogy.
  • #35
Dale, as far as I know maxwell's equation (for light's pressure or momentum) calculates the momentum of a wave incident on a reflector based on a sinusoidal wave -- as my professor shows in his book which I already mentioned. If you do not wish to rework the problem without changing frames -- and NOT introducing yet a potential "third" frame or a condition which upsets the problem I originally posed by causing extra transference of energy which is unaccounted for explicitly *a light source not in either frame of reference?!* -- you will only cause confusion.
If you do not feel like doing Maxwell's equations in a single frame of reference so that all E and H field boundaries can be checked independent of changing frames of reference (obscurely), I cordially thank you -- but ask that you do not post any more in this thread. Maxwell's equations do not require correction by frame changes to work -- and this is a source of confusion that I find unnecessary.
I already worked out the problem for a free mirror for ICH -- which should have save everyone a lot of work and study as even that example shows an error.
Relativity did not help me reconcile the mistake. I fail to see that four vectors is going to do anything except increase the number of potential misinterpretations I might have -- eg: as the information is unfamiliar -- which is why I asked people not use them if possible in the first place.
Not according to what I learned -- in full disclosure. Even if one takes the infintesimal surface, the H field does not have to be zero (or B, if it has the same meaning in your eyes). In any event, in the earlier work you gave -- I do not see that it is possible for E and H to both be zero in the conductor. I suspect, that if your above statement is true -- it is only a partial boundary condition; and the change to B is to obscure things yet more.
The choice of the normal is arbitrary and hides important information at that point. eg: you are choosing the normal at right angles to the information required to solve the problem.
The E field of a square wave at 90 degrees to the direction of travel along the proper axis ( not the cross product ) is set to zero on a boundary. Therefore, it is impossible to have TWO E-fields of differing strengths superposed at the reflection point without having a non-zero E-Field. Even more importantly, the continuity of the E field is violated at a point if that happens -- which is not permitted according to my class on Maxwell's equations.
Actually, I re-read your earlier posts -- and it looks to me that you were being rude, and claiming I am changing the problem by using the power average -- even though that has been in the thread even since the first page. Therefore, I have asked a moderator to look over what is going on -- to give you the benefit of the doubt concerning the credibility of your final post. But I would cordially invite you to end the dialog here. Thank you.
  • Astronomy and Astrophysics
  • Sticky
19K
