- #36
Dale
Mentor
- 35,535
- 13,852
The momentum of a EM field is certainly not restricted to the special case of a sinusoidal (plane) wave. In fact, even static fields that do not change in time can carry momentum. The momentum density is:andrewr said:Dale, as far as I know maxwell's equation (for light's pressure or momentum) calculates the momentum of a wave incident on a reflector based on a sinusoidal wave -- as my professor shows in his book which I already mentioned.
p/V = 1/c² ExB
The transformations are well known and essential to the topic of this thread (since you are interested more than one frame) so I don't really see the problem here. One of the practical reasons for learning how to do transformations is exactly for this kind of situation, so you can transform it to a simpler coordinate system and solve an equivalent but mathematically easier problem.andrewr said:If you do not feel like doing Maxwell's equations in a single frame of reference so that all E and H field boundaries can be checked independent of changing frames of reference (obscurely), I cordially thank you -- but ask that you do not post any more in this thread. Maxwell's equations do not require correction by frame changes to work -- and this is a source of confusion that I find unnecessary.
If you know the correct boundary conditions for a moving conductor then I would be glad to check and see if my solution satisfies it, but since it satisfies the appropriate boundary condition in one frame then it must do so in all other frames also.
I strongly recommend that you make the effort to learn four-vectors. Minkowski geometry (of which four-vectors are an essential part) is the mathematical framework of SR, it vastly simplifies and clarifies SR.andrewr said:I fail to see that four vectors is going to do anything except increase the number of potential misinterpretations I might have -- eg: as the information is unfamiliar -- which is why I asked people not use them if possible in the first place.
I don't know what you mean by a partial boundary condition. The only boundary conditions I know about for the surface of a perfect conductor at rest are nxE=0 and n.B=0.andrewr said:I suspect, that if your above statement is true -- it is only a partial boundary condition;
The normal is not arbitrary at all, it is completely determined by the geometry of the mirror. In this case the mirror is the plane x=0, so the normal is unambiguously (1,0,0).andrewr said:The choice of the normal is arbitrary and hides important information at that point. eg: you are choosing the normal at right angles to the information required to solve the problem.
oh come on. You said the exact same thing to me earlier plus several other minor rude things. You can go ahead and complain to a moderator but nobody is going to censure me for my conduct here. This has been a reasonably tame thread overall.andrewr said:it looks to me that you were being rude, and claiming I am changing the problem by using the power average -- even though that has been in the thread even since the first page. Therefore, I have asked a moderator to look over what is going on
